Box Rocket Homemade trailer build.
cruiseroutfit
Supporting Sponsor: Cruiser Outfitters
It was like an 'everything Toyota but Land Cruiser' weekend, OK we did have a 40 and an 80 along. Great pics as usual Adam :cool:
Hey adam, what are the dimensions of your trailer? LxWxH Height being of the actual box itself. looks awesome, im basing my trailer build off of yours!!
Box Rocket
Been a while since I've updated this but it's also been a while since I've changed anything. Last fall I decided to clean up the fenders that had been badly peppered by rocks. The paint was chipped badly so I decided to repaint the fenders with some Spray on Bedliner. I just used the Rustoleum spray cans. turned out nice, but I'm sure it won't hold up quite as well as "pro" bed liner. That's ok.
Here's a few pics after the fender repaint.
So finally, the most recent change was with tires. I have been running these 315 75R16 BFG's on 80 Series Land Cruiser wheels for a while. They're worked out great but are just a touch too big in the fenders. 99% of the time there were no problems but big high-speed hits in the desert would put them into the fenders a little. I didn't want to destroy a tire out in the middle of nowhere so I started looking at options. At first I planned to redo the fenders, but that seemed extreme.
trailer with 315s filling up the wheel wells
Then a couple months ago I bought a new set of tires for my Tacoma. I removed the 33x10.50s that were on the Tacoma and used one of them as the spare for the new set. That left me with 3 of them left over. As a Toyota guy I wanted to stay with some Toyota wheels so I found 3 early 4Runner alloy wheels in the right size and cleaned them up and painted them. This gave me a full set for the trailer (including a spare) that will fit a little better in the wheel wells and has less rolling resistence to improve towing.
33's giving a little more room in the fenders.
Looking forward to some wheeling/camping soon now that the weather is getting better.
jkce72
Nice. Your trailer was always kind of the blueprint I used to build mine. The new wheels and tires look great. Happy camping.
Hey Adam,
Just wanted you to know I'm about to copy your trailer so that I can more efficiently pack away the goods for my wife and two daughters.
Great work!
I think it's about 700lbs
Loaded, right? How has the trailer design held up to the rigors of "expeditioning?" It has been suggested to me to use 3/16 or 1/4" walled tubing for the frame but I feel that is overkill. So, seeing you use 1/8 is interesting. In my mind that seems plenty rigid enough.
Thanks for your comments.
Box Rocket
Thinner wall tubing is fine if you have enough crossmembers. I have never had an issue at all with mine. A lot will also depend on the amount of weight the trailer frame needs to support. 1/4" is completely overkill IMO and unneccessary and just adds a TON of unneeded weight that you now have to tow around. M416s frames are 1/8" wall and they aren't even boxed tube.
RJ40
Quote: " bolted a HD swivel caster to the skid so I can roll it around easier."
How big is that wheel and where did you find it....it is just about exactly what I've been looking for.
Thanks!
Cheers!!
rockwood
Dumb question: Where's the trailer's number plate? I need to do remount mine as the plate is all twisted from hitting the dirt......its just too low!
Box Rocket
Thanks!
Cheers!!
The wheel is ~6" diameter. I found it at a local warehouse for ship damaged goods.
I don't have a number plate. It's not required in Utah for this size of trailer.
Adam, what are your thoughts on the 16 gauge sheet metal you used on the trailer? I found a couple of calculators that estimated about 52lbs for my dimensions of 48x64. Would need similar for the lid too... I'm just wondering if a lighter gauge could be used and what might be recommended.
Rinzlerz
