Expedition Portal Forum
Go Back   Expedition Portal Forum > Expedition Campers > Expedition Trailers: Sponsored by AT
Expedition Trailers: Sponsored by AT A forum to discuss expedition trailer options, builds, modifications and designs. Sponsored by www.adventuretrailers.com
Reply
Thread Tools Search this Thread Display Modes
  #11
Old 10-15-2009, 07:48 PM
REasley's Avatar
REasley REasley is offline
Default
How about this for a hinge. Simple, weld-on, available in many sizes.
http://www.allegiscorp.com/DisplayPa....jsp&cat=Hinge
  #12
Old 10-16-2009, 06:38 AM
Airborne Lee Airborne Lee is offline
Default
I have used a 1" tube under the lip bolted to the bucket. This will be removable. I welded the first two hinges to the lid and it works. Two more to go. Then I'll tackle the sheetmetal to the frame. Pictures by the weekend.
__________________
Red, 01 WJ 4.7L 2.5"BB, 31"AT/Ko's, QD, UC, Nerfs, Rack, CB, GPS, M416 Trailer
Blue, 01 WJ 4.7L stock
member of: www.jeepforum.com & www.kcjeepclub.org
  #13
Old 10-16-2009, 07:46 PM
wompser wompser is offline
Default
hey there,
I had the same problem of owning the "bungs" but not the bracket for them, so... I made my own.
it was pretty simple really, check out a couple pictures on my build page.
http://forum.ih8mud.com/trailer-tech...ler-build.html
and sorry for the cross-posting... I maybe should have done the build on expedition portal vs. mud, but I had to choose one!
  #14
Old 10-17-2009, 03:20 AM
d0ubledown d0ubledown is offline
Default
for my lid, i used 3 heavy duty stainless door hinges with needle bearings. bolted onto angle iron which was welded to the lip. the cdn m101s have a square lip, similar to the rounded lip of 416s. nuts are welded to the inside for ease of removal. works great so far...no issues. my lid w/ thule bars probably weighs in at 100-120lbs.
my tailgate has those weld on bullet type greasable hinges.
__________________
sonny
old ride: 1998 4Runner. built. wheeled. sold.
new ride: 1997 FZJ80 arb, ome, bfg, billes, etc...
chaser: cdn M101 spring over, FZJ80 wheels, 295's, capped & racked.
  #15
Old 10-17-2009, 03:08 PM
Default
Quote:
Originally Posted by wompser View Post
hey there,
EXCELLENT build thread! Thanks!
As you can see from my picutre My issue is not the bracket that holds the stopper to the bucket. it is the circular plate that welds to the bucket that the stopper sets up against and the retaining bracket screws into. Mine is completely missing. I could fab it but I will have to figure out how to get the round hole in the plate with the correct lip to seat the stopper. I can make the plate square.... but still the hole is my issue. As you can see, the bracket screws into the plate which has an inner and outer lip. I am not sure how to get there?
I'm welcoming idea's.
__________________
  #16
Old 10-17-2009, 03:32 PM
Default
Hinge update...
http://www.expeditionportal.com/foru...014#post486014
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright, Expedition Portal 2005-2009
