Expedition Portal Forum
Go Back   Expedition Portal Forum > Expedition Campers > Expedition Trailers: Sponsored by AT
Expedition Trailers: Sponsored by AT A forum to discuss expedition trailer options, builds, modifications and designs. Sponsored by www.adventuretrailers.com
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 10-25-2009, 09:39 PM
wyorunner's Avatar
wyorunner wyorunner is offline
Default M416 Hub Conversion to 6 on 5.5?
Alright everybody, ive looked a pretty good amount with different phrases here and used google, probably should have kept searching but I figure someone will know or have an idea.
What I want to do is run Toyota wheels on my M416 and keep the parking brake. Basically would like to swap just the hub to a 6 on 5.5 pattern not buy a whole new axle. Has anybody done this, seen it done, or have any information on how i can go about doing. Especially since I already bought a set of matching rims to my current sport rims on my 4Runner. Any Information, websites or part numbers would be greatly appreciated.
Thanks,
Turner
__________________
http://turnerandmoose.blogspot.com/
2002 4Runner
1967 M416
  #2
Old 10-25-2009, 11:20 PM
fireflyr's Avatar
fireflyr fireflyr is offline
Default
Here's a link for hubs that convert a Canadian M101 trailer:
http://www.southwestwheel.com/store/...Name=l0655lb3e
And here's why they may or maynot work:
Quoted off IH8MUD: Those hubs are for the Canadian M101 trailer. If the M416 you own uses the same size bearings for the inner and outer bearings. Then there are no replacement hubs for that axle with the Toyota lug pattern. Some of the last M416s were built with the 3500# style axles (larger inner bearing and smaller outer bearing) and you can get the same hubs that are used to convert the Canadian M101 over to the Toyota pattern to convert that type of axle.
Here's a link to the whole thread:
http://forum.ih8mud.com/trailer-tech...onversion.html
I gave up on the idea on my M100 and made a mount for a spare. Good luck and post up if you find something else.
Things have changed color a bit
__________________
'67 FJ 40 with '73 F.5 engine, dune beige 416, Ehsan green canvas top, Safari 4" lift, OME shocks
1951 M100 trailer, SOA, (restored, sort of)
2006 Dodge Megacab 4x4 CTD
  #3
Old 10-26-2009, 12:27 AM
wyorunner's Avatar
Default
I found 1 option, i think its the same one in that thread over on ih8mud, and then desertdude did it on his M101. Im not currently with my trailer or id already be on the way to figuring this out. I need to pull the wheel and drum and hub to figure it all out. I will do that when i get home. Hopefully someone will be able to provide us with some insight before then.
__________________
2002 4Runner
1967 M416
  #4
Old 10-26-2009, 12:38 AM
xcmountain80's Avatar
xcmountain80 xcmountain80 is offline
Default
Why not just swap in a new axle with electric brakes?
A
  #5
Old 10-26-2009, 03:18 PM
fireflyr's Avatar
Default
Quote:
A
The brakes are for parking only, actuated by a lever mounted on the front of the trailer.
__________________
  #6
Old 10-26-2009, 03:38 PM
Default
Quote:
You misunderstood, I asked why not purchase a new trailer axle with electric brakes......controlled via a brake controller inside the cab using a 7 way round plug. I wish there was a way to engage elec brakes when the trailer is parked w/o running aux. batteries down. An arb air locker style air brake would be way cool!
A
  #7
Old 10-26-2009, 04:23 PM
ntsqd's Avatar
ntsqd ntsqd is offline
Default
Presumably if the brakes are electric then some method of energizing them mechanically could be devised. The electric brakes work via an electro-magnet on a lever. Pull on that lever with a cable and you've got a parking brake.
For the hassle why not just carry some chocks? The TrailBlazer is a similar sized trailer and only when parking it sideways in my driveway have I wanted or needed any sort of chock.
__________________
I used to swerve around my hallucinations, now I drive right through them.
  #8
Old 10-26-2009, 04:35 PM
wyorunner's Avatar
Default
I dont need electric brakes, ya id like them but dont need them. I may go that route one day, but for now i like the current setup, and its cheaper to not buy a whole new axle. Mind you, if i have to swap the whole axle to be able to run 6 on 5.5 YES i will get electric brakes, even though i dont particularly want to re wire the truck, oh well. So far i take it no one has converted from 5 on 4.5 to the 6 on 5.5? I think what im going to have to end up doing is find bearings that fit the drum off redneck-trailers.com and the axle that is on the trailer(original).
__________________
2002 4Runner
1967 M416
  #9
Old 10-26-2009, 05:01 PM
Default
Quote:
Ha redneck trailers, they: well one of their offices in in Tampa not that ithelps you but I know were it is. If you don't have to replace the hub assebly you could always opt for hub converter like a spacer just with an incoming lug pattern and an outgoing one.
http://www.ezaccessory.com/Wheel_Ada.../5450-6550.htm
but for $129 I mean a new elec braked axle is $360
A
  #10
Old 10-26-2009, 06:08 PM
njtaco's Avatar
njtaco njtaco is online now
Default
For both (all) of you, Dexter makes an electric brake equipped axle WITH a cable actuated parking brake as well.
PAGE 27
__________________
03 Taco (Gone, and missed...)
88 FJ62 3FE, auto, etc. For Sale to the right buyer
07 DL650, lightly farkled
Member #160
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright, Expedition Portal 2005-2009
