Expedition Portal Forum
Go Back   Expedition Portal Forum > Expedition Support Equipment and Adventure Activities > Adventure Activities > Water sports: Kayak, Surfing, etc
Water sports: Kayak, Surfing, etc Sailing, Kayak, Canoe, Surfing, etc.
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 03-11-2010, 05:21 AM
Jnich77 Jnich77 is offline
Default Maximum distance between racks?
Hello, I am thinking of putting some kind of cradles on my camper to hold two kayaks. I have a "jumping jack" camper, and it has rails ad both ends.. about 8' apart. I was wondering if this is too far apart to support a 12-14 foot Kayak?
I will probably take off the hoops holding up the back of the john boat so they are not causing so much drag. Going over it in my head it looks like I can have two kayaks on top, and still have plenty of room in between for gear and coolers.
I was also curious about the racks that hold them on there side, any advantages other than freeing up more storage space around the boats? The only time I have hauled kayaks is on a home made rack on a utility trailer, I am really trying to do this in a less ghetto fashion...lol
Btw: The kayaks will be of the sit on top plastic variety if that makes a difference. This is the last time I hauled kayaks to the keys, seems to work great. The supports were 8' part. Pulled it behind a 2006 Jetta TDI, got 36 MPG doing 75-80...lol
__________________
A violent action will beat a well thought out plan every time
2002 Toyota Tundra TRD
2008 Jumping Jack
2005 Honda CB 900
1987 Yamaha BW 350
  #2
Old 03-11-2010, 07:58 AM
Expedition Key's Avatar
Expedition Key Expedition Key is offline
Default
Looks like your jon boat had a rough night!
__________________
2009 Tacoma TRD 4x4 Access cab, Toytec 3.5" coilovers, rear add a leafs, Bilsteins and airbags, 255/85/16 BFG ATs
  #3
Old 03-11-2010, 08:03 AM
Default
Yeah...it had a tree fall on it... so its not so dent free anymore..lmao. Looking to replace it with two kayaks... or possibly a ganoe since I have a 5.5 outboard to push it... will probably stick with the kayaks since they are zero maintenance or registration fees.
__________________
2008 Jumping Jack
2005 Honda CB 900
1987 Yamaha BW 350
  #4
Old 03-11-2010, 01:54 PM
wcdu wcdu is offline
Default
Heve you tried the Jumping Jack web site? They have a bunch of new options since I bought mine.
Steve
  #5
Old 03-11-2010, 01:56 PM
Nullifier's Avatar
Nullifier Nullifier is offline
Default
It is really important to have your racks no closer then 3' from either end of the kayak. The reason is if it is any closer, the straps can come loose due to the taper and narrowness of the bow and stern stems. If you have a 14' kayak no more then 8' apart, a 12' kayak no more then 6' apart, a 9 ' kayak no more then 3' apart. If you stick to that and strap then down correctly you will never loose one.
__________________
Canoe Escape Blog
Nullifier Tacoma
  #6
Old 03-11-2010, 02:58 PM
DesertBoater DesertBoater is offline
Default
Quote:
While I'd also tend to recommend strapping closer to the middle than you're planning, I'd also suggest that if you can't find a way to position the racks any closer, you can always run a strap through a grab-loop or a drain-hole just to be sure that even if they do come loose, they won't fall off completely. I was on a swiftwater rescue course last spring and at the end of the day we were loading boats onto my truck and when the last boat went on (stacked on top of all of the others) I told my buddy who was tying them down to be sure to go through the grabloops. He responded that it wasn't necessary and not to worry about it...well you can probably guess what happened. the first stop sign I got to, I had a bright yellow piece of plastic rocketing toward my hood, it then bounced out and into the middle of the empty intersection. I've heard stories like this about really nice carbon ($3,500) sea kayaks too.
It's definitely worth the extra work to tie things on right, than to face the walk of shame on the road.
Cheers,
West
  #7
Old 03-11-2010, 08:38 PM
Default
Quote:
Steve
Humm, I'll have to check it out.
__________________
2008 Jumping Jack
2005 Honda CB 900
1987 Yamaha BW 350
  #8
Old 03-11-2010, 08:40 PM
Default
cool, thanks for the advice.
__________________
2008 Jumping Jack
2005 Honda CB 900
1987 Yamaha BW 350
  #9
Old 03-11-2010, 08:44 PM
Default
Cheers,
West
LMAO...I have had that happen with lumber.... learned a expensive lesson...
__________________
2008 Jumping Jack
2005 Honda CB 900
1987 Yamaha BW 350
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright, Expedition Portal 2005-2009
