landshark23
so i finally bit the bullet and installed my CB radio this to day over all it was an easy install the hardest part of the install was deciding were the heck to put the dam thing. i finally decided to put it in the center consul right below my radio. I think this was the cleanest place to put it there are no wire showing and it look like it was meant to be there. please tell me what you think of it
installing the radio took some time about 3 hours worth of work and a 6 pack. the first thing to do is remove center panel. there are five screws that hold this panel in and two of there are hidden well thank you toyota. after you remove these you just pule the center panel off.
Next i puled the radio out and did a quick test fit to see if i could fit the radio in the area below the radio. It was snug as a glove and worked perfectly.
after test fitting the radio i ran the power wires and the ground. i wired the orange wire to the cigaret lighter(green is power) and the red directly to the battery. the ground wire was attached to the mettle harness behind the radio.
after wiring up the radio i needed to modify the radio harness there were two thing that need to be done to it. The first was to grinned out part of the harness to make it possible to screw the CB radio into it and support it. next was to grind off sever small bumps shown in the second picture this made the radio fit in a little better
the dots are circled in red there are two on each side
after getting the radio harness ready for mounting the CB radio i attached the coaxial cable and the 90 degree fitting the 90 degree fitting is necessary to make the radio fit in flush and not stick out.
you can see that the 90 degree fitting make the cable flush with the rest of the wiring
now ever thing goes back in the way it came out are you suposed to have extra screws o well must have not needed them LOL all finish with the radio. so what do you guys think
