rstl99
Hi again.
As I indicated in my Alaskan purchase post, I'd like to re-seal and re-caulk my Alaskan while in the garage this Fall.
Attached is a picture of mine with arrows to show the places I figure should be re-caulked with new sealant, and would appreciate confirmation from you that these are the spots that should be addressed, and whether I am missing some.
I also want to either adjust the top door so it shuts more snugly, or install a thicker sealing strip because there is currently a gap that probably allows rain to get in and accounts for some wood rotting on the bottom of that door.
For sealant, I have been advised by Peter (Basinranger) to use Sikaflex polyurethane sealant (which I can obtain locally). Some of their marine products look particularly well suited:
http://www.sika.ca/ind-mar-mar_prod.htm
Peter also gave insightful advice on areas to deal with:
Looking at the exterior trim it looks like the original sealant - which I wouldn't trust at all - you won't see any evidence of leakage till it's done some damage so to labor the point a bit - I'd re-seal all the exterior trim & penetrations before too long...You've got just a spot of stain on that inner front left top corner which is from the edge trim sealant failing. I'd also pull all the exterior screws, give the holes some sealant if they are sound & a syringe of epoxy if they aren't & re-fasten. That & epoxy seal the exposed bottom ply would give your Alaskan a LONG rot free life. That 40 year old sealant & leaking screw holes are what kill these campers...
Since the aluminum can't leak it's only the screw holes to worry about. After I pull one out if there's no sign of rust & they weren't stripped in the wood stringer that runs under the skin I just put a dab of sikaflex & put it back. If the screw was stripped (well the wood actually) I mark that hole & keep moving doing the sikaflex the holes routine. Later I mix some thickened epoxy, put it into a syringe and pump that into all the bad holes. Next day just sika & replace the screws. Goes pretty fast.
These things live outdoors just fine - as long as all the holes in your skin are sealed. The original sealant was a mastic like you describe - pretty good stuff but asking it to last 4 + decades...? It will still be flexible & look ok and leak like hell - at least that's my experience. Polyurethanes like Sikaflex are vastly superior.
Any other recommendations (places to reseal, and/or products to use)?
Thanks a lot!:ylsmoke:
--Robert
--Robert
