| Toyota: Land Cruiser: Sponsored by TLC Discussions specific to the modification and service of Toyota Land Cruisers for Expedition Travel. Sponsored by www.tlc4x4.com |
Thread Tools | Search this Thread | Display Modes |
#41
Quote:
__________________
1991 Toyota RN110 (Imelda the Rubicon-proved Hot Rod IFS Hilux) 1992 WilderNest Adventure Camper TLCA# 10427 "If you want to know who is going to change this country, go home and look in the mirror." --Maude Barlow |
#42
That's a fact, and one of the advantage of. Basically available everywhere through Napa stores.
Quote:
__________________
2008 Kimberley Kamper SportsRV 2006 SR5 V8 4Runner 2001 BMW R1150GS "Big Bird" 2000 VW TDI- our economy, road trip car 1996 F350 Crew-Cab Diesel |
#43
Quote:
__________________
2002 Jeep Liberty Limited 4x4 OME heavy springs Bilstein front struts and rear shocks Yokohama Geolander AT-S 245 75r16 |
#44
__________________
2002 Jeep Liberty Limited 4x4 OME heavy springs Bilstein front struts and rear shocks Yokohama Geolander AT-S 245 75r16 Last edited by calamaridog; 11-29-2007 at 08:39 PM. |
#45
Quote:
I picked the Hundy up at ~70k with no knoweldge of its past life, so the 3 analyses I've had on her have come up outstanding.As for my 80 I have had it since she was 1yo, so for the most part know every last detail on her trail of life, do also run M1 and the 61010 filters. When her head was off by Robbie he did make a comment about its cleanliness and asked if I ran syn though I was out-of-town to have noticed it myself. I am lucky in that my 80 has always been the ``expedition rig'' and has only really sees highway en route to adventures and off-highway stuff. The similar mileage I have on her though I would guess is much higher % of off-highway than most. On all my vehicles I change the M1 every October, regardless of mileage. I am such a believer in M1 that the used drained oil from the Cruisers is put into my commuter car for a second life, and it is ticking better than ever at ~200k.
__________________
Pskhaat (Scott) UZJ100 "Mama Cruiser", FZJ80 über rare "Geen", FJ45 "Ridin' in the Poopy with Dada..." |
#46
VERY interesting that your V8 has only been in your position since 70k. That means that ‘normal’, ‘typical’ maintenance before your got it and started running Mobil 1 didn't hurt it one bit :-)
Quote:
__________________
#47
calamaridog/pskhaat
Do you guys know the outer diameter of the M1 209 filter? After searches online and phone calls, I have found larger filter solutions from Donaldson (P550400) and Fleetguard (Cummins LF3339). These filers have very similar physical attributes, Overall Diameter, gasket inner/outer diameter, but longer, which is good. These filters (size) don’t a direct match that’s synthetic media. The closest I have some is a Donaldson P169071 which has an outer diameter of 3.67-in, and is 5.32-in. long. Fleetguard’s LF3487 has an outer diameter of 3.78-in and is 5.4-inches long. (The Donaldson’s is very close to my Toyota filter, with an O.D. of 2.85-in and I.D. of 2.47) The question is, will the gaskets on these larger diameter filters fit and seal properly on the mounting surface. Hence my question, the outer diameter and more importantly, the inner/outer diameter measurements of the M1 209 filer’s gasket.
__________________
#48
calamaridog:
Thanks for the link to the ih8mud thread about the Mobil 1 oil analysis numbers, I just finally read it. Very impressive 12,000-miles and lots of idling! After much searching for a commercial application, heavy-duty oil filter from Donaldson or Fleetguard with synthetic filtering media (or a blend) I came up empty. Lots of filters with regular cellulose media, but no synthetic media upgrades. Commercial application stuff is not always the best choice, but I gave it a hell of a try (web and technical support calls to Donaldson and Fleetguard). Web searching and reading gave a few testimonials about the Mobil 1 M1-209 filter (in addition to the comments here) that convinced me to give the Mobil filter a try. I found them easily at my local Kragen/chain auto parts store for $9.99 each. I bought two. They also had the similar K&N, which I read is made by the same people for both Mobil and K&N, but the K&N was $11.99 and has the nut on the end for easy removal. I prefer the Mobil with normal end that also fits the end cap type filter wrench I already have. The only slightly negative thing I can say is that the ends of the filters are not sealed with plastic like the Toyota OEM and commercial filters I buy. Now I'm looking forward to my next oil change and running more miles, probably 7,500-10,000. I have to decide if I'm going to send my oil to Blackstone, or to my local CAT lab that I have used in the past. I like all the written comments given in the examples in the ih8mud thread. In the past my local lab didn't write nearly as many words to help a layman interpret the analysis. Do you know if Blackstone accepts a new, baseline sample of the oil before you start testing with them? My Red Line 5w-30 is probably not a common oil? James Quote:
__________________
#49
James,
I was going to say measure and make sure that filter fits your 4runner before you drain the oil. I think it does from memory. It works great with the motor, but I can't say 100% it physically fits the 4runner application, whereas I know it fits the 100 series.
__________________
#50
Give the OEM Japanese filter a try. 90915-20004
http://www.mkiv.com/techarticles/par...ter/index.html |
| Display Modes | |
