Mounting a swing back trailer jack
ih8philly
I want to replace my swing back trailer jack. There doesn't seem to be any that are made to fit the 2x2 tubing of my trailer tongue. Most seem to be designed to fit a large range of tongue sizes and because of this they have a bunch of extra metal on one side like so:
I ran across another trailer similar to mine that had a very nice looking mount like this:
Does anyone know what that mount is called or where I would get one? Or is it just something you would custom fab?
Mark Harley
If you have a jack already, Cut a plate to weld to the tongue.
Drill matching bolt holes and bolt the jack on with short bolts and lock nuts.
I was never a fan of the clamp on tongue jacks. I like the revolving jacks that use a weld on tube and pin set up.
ih8philly
Thanks, but why is welding a mount on better than bolting it on? Welding seems like a lot more work for someone like myself that doesn't own a welder.
Mark Harley
To each his own,
Just looks better to me.
The bolt on mount is huge compaired to a weld on ring.
You can always find a welder if you go the weld on route.
ih8philly
Just to close this thread out in case someone finds it in the future. I was never able to find anything to my liking. So I ended up getting something custom fabricated. Came out great and much nicer than the mount that comes with the jack. Just needs a little paint now.
highlandercj-7
I agree with Mark. I like that style better too. It's cleaner and strong.
Philly, that is a nice mount for that style jack, very good work.
That's very clean looking. I like it.
Aspen Trails Trailers
Supporting Sponsor
I think you made a wise choice. The jacks that are stationary are not a good fit for off roading. That point is the lowest point of the trailer and will drag bending the jack straight back, making is useless. Nice fab work on the bolt on.
Bob
www.aspenXtrails.com
951 692 0958
Arlo
I prefere the weld on bracket to the frame.
No corrosion between the parts is possible. The connection is stronger.
Mark Harley
Bob
The weld on ring style folds back flush with the tongue, Or pull the pin and remove it.
Supporting Sponsor
Don't think I have ever seen one on an off road trailer, but I seldom pay much attention to them to be honest. I was thinking it was electric welded to the Aframe.
I use the welded ring on mine. I have 5 attachment points on the new trailer. I have removed it from the equation if the owner desires to. They are for stabilization and tire changing.
Bob
951 692 0958
ih8philly
Bob
951 692 0958
Thanks Bob, I wish I could take credit but it was created by the guys over at Jeeperformance Inc.
I would be afraid of the force that it would take to remove this mount. Welded or not, this mount would certainly out live the frame.
WonaWarrior
