Page 1 of 2 12 LastLast
Thread: Differential Question
  1. #1
    Join Date
    Dec 2007
    Location
    Slo CA
    Posts
    263
    Default Differential Question
    I am in the process of designing a camper for a Dodge 5500. The 5500 has brand new axles that have ratings of 7000 lbs front and 13,500 lbs rear. Since my gross weight will be around 12,000 lbs I figure it should be a pretty reliable package. My dilemma is no one makes any lockers for these axles. Dodge offers a rear limited slip as an option.
    So here is my crazy idea. I have read on other 4x4 forums of rock crawlers using line locks on the individual brakes. The idea is when a tire spins/ is airborne, lock that brake and the other side gets driven through the diff. This also is convenient for making very tight turns, which may be very convenient on a large truck. The turn is done by locking the inside rear and then when you apply power the truck pivots about the locked rear tire.
    So will this work on a vehicle designed for more "expedition" type use? I figure the wheel brake feature will help me since without lockers I am more liable to get stuck.
    I plan to order the truck soon and I need to decide whether or not to get the limited slip diff. I expect you can not use the wheel brake feature with the LSD since the LSD will be fighting you if one wheel is locked.
    Any comments appreciated.
  2. #2
    Join Date
    Aug 2007
    Posts
    675
    Get the LSD and try it first, without the line locks. Having driven a lot of various configurations, I gotta say that limited slip is a lot more useful than folks on certain websites give it credit for.
    If you do decide to plumb individual line locks - you won't likely be locking them at full "everything ya got" pressure anyway so it should not be negatively affected by the limited slip and vice versa.
    Be sure to check laws concerning street legality of vehicles with brake locks.
    Heavy: 2001 ZR2 Blazer
    Light: 1992 Tempo CNG/E85/Gasoline
  3. #3
    Join Date
    Aug 2006
    Location
    Sugarloaf mtn, Boulder, CO
    Posts
    841
    I would first drive the truck with the standard axles and the LSD - which will help. I very rarely use the lockers on the mog and when I do you could most certainly get by without them. With such a heavy (probably top heavy) vehicle you are not going to be climbing rocks and driving on real nasty trails so the only thing you really have to contend with is mud and snow. In these situations its debateable whether or not lockers help. My mog is more squirmy in snow with the lockers on that when they are off. On trucks this size the first thing it to make sure the front wheels are directly driven either by a tcase or a locking center diff in the case of a perm 4x4.
    Using the brakes is a definate option but you really need to understand the system on your truck and the situations you'll be in, it might get old quick when you need to use it. One of the most useful techniques for driving a Hummer H1 is knowing when to use the brakes. Sides effects of the torsion diff can leave a H1 stranded, for example diagonal wheels off the ground. The torsion diff can only multiply the torque going to the lowest power wheel on the axle - 5x (for example) the torque required to spin an airbone wheel is not enough to move the truck. Gently holding the brakes gives 5x times the brake force to the other wheel which is enough to overcome the brakes and move the truck. Even with a torsion diff it can take a huge amount of brake effort to force the other wheel to go around.
    Rob
    You don't inherit the world from your parents, you borrow it from your children.
    1979 Unimog 416 Expedition Camper
    1974 Unimog 421
    2004 Dodge Ram 2500, 4x4, Double Cab, Cummins Turbo Diesel
    2006 25' Airstream International CCD
    2009 Harley Davidson
    Sugarloaf, Boulder, CO
  4. #4
    Join Date
    May 2007
    Location
    Vista, North SD county, CA
    Posts
    571
    Some good detail, Rob. Do you mean "Torsen" diff.?
    Bill - K7WCC - 2004 GMC Envoy
    Build: http://forums.offroadtb.com/viewtopic.php?f=25&t=202
  5. #5
    Join Date
    May 2006
    Location
    Atlanta
    Posts
    1,773
    Quote Originally Posted by TheRoadie
    Its a type of limited Slip that uses a worm gear set up instead of clutches like most LS's use. Torsen in the brand.
    http://www.torsen.com/
  6. #6
    Join Date
    Aug 2006
    Location
    Posts
    841
    Yes, I do.. Its one of those days..
    Rob
    1974 Unimog 421
  7. #7
    Join Date
    Dec 2005
    Location
    Sandy, UT
    Posts
    6,202
    Rockcrawlers don't use the Line-Locks for axle control (they have lockers, no need), rather they use them to "pivot" or "front burn" using the front drive only and one rear tire or the other locked. We ran this way in the comb buggy I competed in, very useful.
    The way you are describing is basically how the Toyota A-Trac system works (as I understand it), it basically uses ABS senors to detect unequal spin, and applies the brakes as needed.
    In the real world, short of it being computer controlled, I think it is very impractical at best. While there may be certain situations where it is useful, I don't know that you'll find your 12k lb beast in them. Mud, sand, snow... I'd think that by they time you even realized you needed to operate the linelock (which requires pressing the brakes and then locking the fluid at the tire), its too late, your stuck.
    What axles are they?
    Kurt Williams
    Cruiser Outfitters
    Your original outfitter for OME - ARB - AA - Safari - Helton - Engel - Since 1992
    Join us on Facebook
    ExpeditionUtah - A lifelong project of exploring Utah
    kurt@cruiseroutfitters.com
  8. #8
    Join Date
    Jan 2007
    Location
    Tucson, Az
    Posts
    3,729
    I run a 4Runner with Atrac. It works great when you pick a line and drive through it at a consistant RPM. If you are starting and stoping on rocks, a mechanical locker is far superior. In most overland conditions Atrac is all you need. If you plan to run more technical trails, A locker is the way to go.
    Brad
    My Photo Gallery
    2004 4Runner - 2011 Kimberley Karavan
  9. #9
    I don't believe that line locks will accomplish what you want. Even for something more suitable for hydraulic locks, such as locked wheel pivots, your heavy and longer wheelbase truck won't respond to a locked wheel the way you think it will, in my opinion. More likely to happen is if you lock one wheel, the truck will simply drag that tire down the trail. Besides, pivot brakes, as used on sand buggies and rock crawlers, are generally not line lock units (lift button locks), but hand-brake type devices so that the amount of brake force to a given wheel can be modulated. A line lock does not modulate brake pressure, it simply interferes with release of hydraulic pressure in the line that you lock. Trying to set it at other than full lock probably won't work the way you wish.
    As mentioned above, lockers don't get used all that often when use of the locker is selectable. I rarely use my ARB's, even in the mud. The limited slip should be sufficient and is a factory item, which means it will come installed and warranted. A good LSD could be all you need. If you plan to go where you can or likely will get stuck anyway, you will need a winch whether or not you have a locker.
  10. #10
    Join Date
    Dec 2007
    Location
    Slo CA
    Posts
    263
    Thanks everyone for all the great input.
    Looks like the LSD is the way to go. Time to get out the checkbook.
    I'll post an update as I progress.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
