I run this stuff in ALL of my bikes and ATV's and it works. I race cross country and hare scrambles, when we get into some tight nasty stuff with killer hills and we work the crap out of our bikes there is always a pile of steaming bikes. The common fix, especially for the KTM crowd (and mostly due to the HP not crappy bikes) is electric fans, bigger rads. It sometimes is enough. We are not boiling over by much, maybe 10-20% and not all the time, but it's an issue that can put you out of contention pretty quick. With Evans in the cooling system, stock rads, no electric fans, I NEVER boil. That being said, it is cheaper to run a premium coolant. I use caution when in these situations and try to get moving ASAP to get the airflow, but it's an edge for sure. The electric fans on my 700 Kawasaki quad run substantially less than when the system had glycol based coolant in it, I would say the thermal properties are better as well. I really like the fact that there is almost no cooling system pressure with this stuff, pop the cap off at operating temp and no burst of coolant, makes me feel a little better if my son or I ram a stick or something through a rad and don't have to deal with pressurized steam.
For the diesel stuff, I can see how the different fan settings and increased running temperatures are beneficial, engines are not the most efficient at 200 degrees, its just where conventional coolants are happy. A few years back some engine manufacturers were having issues with cylinder liners pin-holing from the outside in. I have seen this on 3406 Cat engines myself, and they were generally not susceptible to that condition. The pin holes were caused by localized coolant boiling on the surface of the cylinder liners while under high load, the cast iron was deteriorating because of it, Water Wetter was actually recommended to prevent this condition, this is a condition that can also introduce air into a cooling system. I will be putting Evans in my F-650 as soon as I swap my camper over from my F-700, it has a Cat C7 in it with almost no miles on it so my train of thought is put in a premium coolant now, and it will pay for itself over time. How much longer will a gasket or seal last with no pressure on it? With a much friendlier coolant that glycol working on it?
