Thread: suspension needs for FWC
  1. #1
    Join Date
    Jan 2008
    Location
    colorado springs
    Posts
    81
    Default suspension needs for FWC
    Does anybody have an opinion on suspension needs for a FWC, I have a 99 taco and was planning on putting on OME Dakars and Bilstein 5100's for the rear on it with Bilstein adjustable fronts and OME coils in front. Is this overkill for eventually putting on a FWC or ATC?
  2. #2
    kcowyo's Avatar
    kcowyo is offline Expedition Portal Moderator ExPo Original
    Join Date
    Jun 2005
    Location
    Lander, Wyoming
    Posts
    5,159
    It doesn't sound like it to me.
    Those are all great components for a loaded or unloaded Tacoma. I'm still running stock springs but the Dakars or custom spring packs from Deaver would be my choice when it comes time to replace the stock packs.
    Another popular option with FWC & ATC owners are airbag set-ups from Air-Lift or Firestone. Those help out tremendously with sway, pitch and understeering issues.
    '97 Toyota T100 - some stuff and some stories....
    '85 Toyota FJ6O - fractal cruising
    currently listening to - Jamey Johnson "The Guitar Song"
    recommended reading - Into the Story by David Maraniss
  3. #3
    Join Date
    Sep 2006
    Location
    Bozeman, MT
    Posts
    344
    i think kc hit that one on the head. personally i went with OME spring packs and fabtech shocks. also installed ride rites. i think its overkill but would recommend everything other than the fabtechs, sounds like you have the right idea
    Erod
    2002 Tacoma, TRD supercharger, exhaust, headers, URD 3.4L 5VZ-FE Toyota Truck Supercharger Fuel Upgrade Kit, ARB front bumper, Fabtech coilovers, OME 7 leaf packs, Ride-rite airbags.
    1993 FWC Ranger II
  4. #4
    Join Date
    Sep 2006
    Location
    Sunnyvale, CA
    Posts
    1,129
    No, it's not overkill.
    Air bags can help to level the truck left to right. On my taco the gas tank is on the driver side and all the appliances on ATC is also on the driver sides. I put 20 psi on the driver side and 5psi on the passenger side and the truck sits level. I've 5100 on all 4 corners. Not sure if it has enough damping for the OME coil on the front. Why not use the OME shock to go with it, should be a better fit.
    My 06 Tacoma with ATC Bobcat
    Courage is resistance to fear, mastery of fear - not absence of fear. - Mark Twain
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
