unplannedbbq
Howdy.
My 2wd '86 VW westy weekender is currently doors & windows off, stripped out & getting prepped for painting.
Which means there'll never be a better time to lay down some wires.
She came with a stock 2-battery config, but no shore power hook up. I've got my 12v plans sorted out, but I'm piecing my 120v solution together. I really want a charger to top both batteries (independently) for those nights when I'm parked near an outlet. I'm sticking with my stock separator/relay, so I don't plan on using a single batt charger + battery combiner as my solution. Pretty sure I'll be swapping out my wallmart wet cell house battery for an AGM deep cycle when this is all done.
I'm looking for advice - I think I've narrowed it to these two chargers:
Xantrex Truecharge 2
Noco Genius
Both are dual battery smart multi-step chargers capable of pushing 10amp per batt - each can be set up for different battery flavors (e.g. - wet starting + AGM house), prices are within $25 of each other w/ the Noco the cheaper option.
Noco is smaller, lighter, "waterproof", 90% efficient, 8-step charging, 110v only
Xantrex is 3-step, but supports world voltages (auto sensing 90-260v - I dream of driving this rig outside of North America one day), 80% efficient, hardwired, decent infographic displays, can be accessorized with remote display/control
I've used Xantrex stuff before & I've liked it. Anyone have any experience with either unit?
The rest of the picture - My primary 12v draws are an Edgestar 43 fridge, viair compressor, misc LED interior lights, fans, and seat-heaters that double as bed pre-warmers when my rear bench gets turned into the lower bunk.
I don't use an inverter - most of my gear is 12v, usb, or air-powered. My house batt will likely be a ~60 amp hour AGM.
When I'm plugged in to shore power the edgestar auto-switches to AC, further reducing my 12v amp draw. Either 10amp charger will be able to stay ahead of my nightly requirements.
The basic AC plan:
30amp locking shore plug+Bluesea 8077 Main+"sealed" GFI outlet at the start of the circuit w/ the charger at the end of the run, either hardwired or plugged into a single gang outlet. All wiring will be 3-wire fully insulated "marine romex."
Any and all opinions welcome.
Thanks,
Joe
Noco Genius
The basic AC plan:
Thanks,
Joe
