I think the idea behind these dc-dc or alternator intelligent chargers are fantastic; however, I haven't convinced myself to use one since I installed a 200A Delco 28SI alternator in my rig. Perhaps someone here can tell me what I'm missing.
The Delco 28SI has an internal regulator with a sense circuit. It is connected to my 660AH triple-bank house battery, as well as to the starting battery, via a 275W-rated isolator. Each of the three banks has its own digital voltage and current monitor; the alternator also has it own digital current and voltage monitor. I do not see any evidence of overcharging or undercharging from the alternator. It seems to me that the alternator regulator is intelligent enough (like a 3-stage charger, if not better) to push just the right amount of current and voltage based on the state of charge of the batteries. I have verified my findings, at certain states of charge of the batteries by not only switching the charging source to the generator-powered Prosine 3.0 inverter's 120A intelligent charger but also by checking the specific gravity of the batteries. The alternator charging rivals that of the inverter's charger, except the alternator can pump around 180A into the battery banks, hence shortening the bulk stage.
