Black Friday Ambo
Skillfulist
More things to help anyone that may follow.
Been on emergency work for days, but managed to squeak in a bit of time to get the flashers circuit out and repurpose the flashers to floods.
Before:
After:
Things to note:
This has a BIG draw once all the lights are on at once.
The flasher is ground switched so if you are nuts like me you have to flip the signal wires to the relay and give the switch power from the master in order for the illumination on a normal toggle switch to work.
With that I am out of things that need to get done to wrap up my wiring conversion/ updating and board transplant. Now to just finish the box. Test fit and shakedown in the ambo went well so it's just a matter of having time again.
Curious, when I eventually obtain my own ambo, would I be able to setup RGB lights in the flasher lights? Similar to how you did making them flood?
norcalmaier
