Wonder if you might shed some light on if and how my battery is really losing power.
The State of Charge lights on my charge controller tell me it's dying but I can't imagine how. I get it charged up (green light), and I let the truck sit for a few days and it goes to the yellow light or even blinking red.
So the question is: are the SOC lights accurate? I assume they are, because if I go long enough without driving the truck my CO/LP alarm gives the low voltage alarm. Plus my heater won't work if the voltage is too low...
The next question would be: where is the power going?
I've measured the parasitic draws that I'm aware of with a voltmeter:
There's nothing else connected to the battery as far as I know except:
The battery is a 55 amp hour AGM bought new in December 2012 (I wonder if I should have gotten a larger one, but I don't need much power). There is a separator - SurePower 1314A.
Any ideas or suggestions on how to figure this out are appreciated.
One more piece of info: yesterday the SOC was blinking red. I connected a portable solar panel, looked again in about 30 seconds, and it was at yellow. The panel is a 100 watt panel, and it was partially shaded. Maybe 6 hours later with good sun, the SOC was slow-blinking green which I suppose means it's finishing up the charge.
Thank you.
- Heater draws .02 amps parasitic (draws 1.7 when running)
- CO/LP alarm draws about .01 amps
- LED lights (which are turned off)
- a few 12v outlets, although one of the outlets is a USB outlet with a LED for some reason
- solar charge controller (Morningstar Sunsaver SS20L)
- An extra 5 ft of wire with spade connectors that isn't connected to anything (they are insulated/taped and not sending energy anywhere)
Thank you.
