Biggs Family LR 3
srschick
For those searching in the future:
My issue started with a rough idle when cold which has gotten progressively worse over a few months. Ran fine when warmed up and in closed loop. Then the code started popping up. I disconnected the purge valve hose from the intake and capped off the nipple. The truck idles like it should with the purge disconnected, and drives perfect. The code still appears obviously.
Has anyone else out there found a replacement valve from another vehicle that will work? I know the D2 guys use a Hyundai vale. If I don't have to drop $400 on a $60 part that would be great.
Jim
http://www.landroversonly.com/forums/f41/replacing-purge-valve-assembly-2005-lr3-54287/
jgrillz94
