Page 3 of 3 FirstFirst 123
Thread: Best GPS
  1. #21
    Join Date
    Mar 2009
    Location
    NorCal
    Posts
    3,331
    Quote Originally Posted by Ron B View Post
    I was originally interested in the ipad, but I am not so sure it would be the best solution for my truck -- a lot of vibration, dust, occasional water (if I can't get the top on fast enough). Not sure how the touch screen will handle very dusty environments or if the screen will be viewable on sunny days -- I have seen some of the cases (the Griffin is really cool) but can they be mounted while in the case?
    The ipad may actually be too big, in the griffin case it is more than twice the size of the Lowrance. Does it need an external antenna/software to work like a gps?
    I should point out that vibration isn't really an issue for the ipad. It's completely solid state. As for mounting it, I like the locking ram mount I'm using (w/out the otterbox case). I've read others use a case and a different Ram mount with good success. Not sure if the other mount is a locking one though.
    1989 SWB Montero (3.0L v6, rear LSD), 33" mudders
    1996 Montero SR (3.5L v6, rear Locker), 35" mudders, 3.15:1 xcase crawler gears
    Build Thread: http://www.expeditionportal.com/foru...su-build-up...
  2. #22
    Join Date
    Feb 2011
    Location
    Bay Area
    Posts
    226
    There is holder from RAM that is expandable that will hold the ipad in a heavy case (Griffin).
  3. #23
    Join Date
    Nov 2005
    Location
    Los Angeles
    Posts
    522
    I am intrigued by this -- and will do more research. I do not have an ipad (yes I am the only one) so I will have to barrow one and see approx how much realestate it will take up with the case.
    '97 td Hummer
    39.5's on beadlocks, f+r locked, rock-ram, body lifted, suspension bagged, wallet empty
  4. #24
    Join Date
    Feb 2011
    Location
    Bay Area
    Posts
    226
  5. #25
    Join Date
    Nov 2005
    Location
    Los Angeles
    Posts
    522
    Nice! I will have to check one out with the weather-proof cover on it and see if I can find a spot to mount it that I like (the hummer being so wide might give me some good options without blocking view/other goodies. I am in the midst of some mods to my int now and could possibly fab some places to mount it. Thanks for your ideas.
    '97 td Hummer
  6. #26
    Join Date
    Jan 2007
    Location
    Racine WI
    Posts
    316
    Default Viewing iPad
    One downside I have found with the iPad is that you cannot see the screen with some sunglasses on. Otherwise I am very happy with iPad and expandable Ram mount. For roads you can adjust it to "look" farther away than you can with a car GPS.
    Dave Bybee
    ________________________________________
    If you use it and enjoy it, doesn't matter how much it costs. If it sits around never getting used, doesn't matter how good a deal it is/was.
    2000 TJ
    2004 Tundra DC
    2004.5 Dodge Ram, 4x4, auto, quad cab, LB, diesel, Ute aluminum flat bed
    1998 Alaskan 10 ft cab over
  7. #27
    Join Date
    Nov 2005
    Location
    Los Angeles
    Posts
    522
    I forgot about the polarized glasses issue with lcd's. I imagine some gps units would also have this issue?
    '97 td Hummer
  8. #28
    Join Date
    Jan 2011
    Location
    Kentucky
    Posts
    64
    Just did a test run through my neighborhood with a bluetooth GPS and my jail-broken iPad I. Used a GlobalSat BT-368i GPS, with BTstack running on the iPad. Very, very impressed. Used MotionX HD for the mapping software. It tracked my route through my neighborhood perfectly -- even accurately gauging my Jeep was on an alleyway next to a major road, and not on the road itself. Pretty nifty, since I've never had proper GPS before.
    Big thing -- I've noticed that for small/unpaved roads, Google won't load maps correctly for them. There's a public road, that's only open through certain hours of the day, but Google won't keep route information in it once you export it to a new device. Turns the squiggly little road in to a "as the crow flies" path. Bummer. Not that big of a deal, so long as you use waypoints on the device and don't forget where you're going.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
