PlacidWaters
Tired of the bulk and weight of your Exped MegaMat and how hard it is to get the air out and roll it up? Exped has a new mattress this year that solves all three problems: the Synmat 12.
http://www.youtube.com/watch?v=ftcPbZKf0gg
SPECS:
4.7 x 30 x 70 (That's thicker than the MegaMat)
3lbs 7oz
Insulates to -1F (R-value 5.3)
Packed size: 6 x 12
COMPARISON WITH THE MEGAMAT:
--PACKED SIZE: The Synmat 12 is about 1/3 the packed size of the MegaMat. Significant space saving.
--WEIGHT: Synmat 12 is 2lbs 3oz lighter
--COMFORT: If you rate the MegaMat a perfect 10 for comfort, the Synmat 12 would be an 8.5. The surface of the MegaMat feels both more supportive and softer due to the layer of foam. It also feels more stable---there is a slight tendency to roll and bounce around on the Synmat 12 that doesn't occur with the MegaMat. But I'm guessing that one would sleep just about as well on either mattress. The difference is more esthetic---the soft, even feel of the MegaMat surface versus the thinner, more slippery tubes of the Synmat 12. However, the Synmat 12 is considerably more comfortable than the Synmat 7 and would be the better choice for kayak and canoe camping since it's small enough for those uses.
--INFLATION: The MegaMat is self-inflating. It took me 5 minutes on the first try to inflate the Synmat 12 with the Schnozzel.
--DEFLATION: You have to wrassle with the MegMat, fold it several times to squeeze all the air out, unfold it, and then roll it up. The Synmat rolls up very easily. No inflatable Synmat fits back in its original back so get a larger stuff sack.
--USE ON 32" COT: (Camptime Roll-a-Cot wide): Both work, but the Synmat 12 fits a bit better as it's a couple of inches narrower.
PRICE: The price of both of these mattresses borders on crazy ($200 and $219), but they're worth the price if you do a lot of camping and/or have sleep problems like bad joints. There is only one reason to spend this much for the Synmat 12: for cold-weather camping. There are other similar uninsulated mattresses that do a good job for a fraction of the cost, like the cheap Intex inflatables. (In my experience an insulated mattress is needed when the temperature falls below 60F.) But you can expect an Exped to be quite a bit more durable than cheap inflatables.
BOTTOM LINE: I highly recommended the Synmat 12 for car, kayak, canoe, and motorcycle camping---any use where space is at a premium and the MegaMat is too large or heavy. Not recommended for bike touring---for that you need the smaller Synmat 7. For use with a cot the REI Campbed 3.5 is just about as comfortable, fits better, is cheaper, and has a more comfortable fabric than either of these Synmats. In a previous previous review I explained why the Campbed and the Synmats are all better than the Exped SIM Comfort.
Isn't it good to know that there are so many comfortable mattresses to choose from these days? No more sleeping out on the prairie with your bedroll.
SPECS:
3lbs 7oz
Packed size: 6 x 12
