A/T Chaser for sale
cityblues
Some of you know I purchased this trailer in 2012 from another forum member who had it built to his specs and delivered in 2009; he used it 3 times; I’ve used it 3 times. Unfortunately great plans sometimes get pushed aside creating opportunities for others; so, this is one of those opportunities to own a well equipped Chaser in Bristol fashion to tow on your adventures. This trailer is an attention grabber; each time I’ve had it out people stop to inquire and admire it … and they want one. As you know, these are great go anywhere trailers and I truly hate parting with it, but, it’s not getting used as it should. As the previous owner said: This trailer is ready to hit the road, as is, right now, and is suitably appointed to make an excellent base-camp when you make your destination. In short, it needs a home where it can do what it was made to do. Hopefully, that home will be yours.
Features:
* Trailing Arm Suspension with air struts
* 28" Waynes RV Stabilizer for leveling and stability in base camp.
* 2" Rear Accessory Receiver
* Cargo Box has gas strut assisted lid and has interior LED lights and is water/dust proof.
* Rubber Matting & Cargo Tie Downs in Cargo Box
* Drop Leg Jack with pneumatic tire for better off-hitch maneuverability.
* Powder Coated Nose Box with dual battery set up (2 Valve Regulated AGM group 31 deep cycle batteries, recently updated). 3 fused outlets, battery tray and hold downs. Dual Power Tender: Marinco Charge Pro Series On board 20 Amp (10/10) dual battery charger and maintainer. PowerFilm Solar Foldable Solar Charger, 60 watts (3.6Amps @ 15.4 Volts)
Carmanah RV-25 Amp Solar Panel Charge Controller
Go Power! 1000W DC to AC inverter with low battery disconnect.
* Auxiliary 12V Power wiring w/ night light (back up light) by ARB
* 19 Gallon roto-mold water tank with1.25" opening, 1/2" drain plug and hand pump
*Adventure trailers Scepter can holders (2) with 2 military grade Scepter fuel cans or two military issue water cans.
* Partner Steel 2 Burner Stove with wind screens & Stainless Steel Stove Shelf for hanging the stove on the trailer.
* Utility shelf for Chaser (16.5" x 43" x .75"), shaped and finished hardwood ply with locator pins.
* Engel 45 Engel MT-45 liter Fridge/Freezer with Insulating Transit Bag and Transit Slide Lock.
* Electric Braked Axle Upgrade with 10" drums, includes break-away kit
* Wheel Adapter: 6 on 5.5 with M12 x 1.25 studs, 1.5" thick (6 on 5.5" to match Land Cruiser FZJ80 Wheels powder coated grey) Adventure Trailers has other options that can be had so you can match your vehicles wheels if you like.
* x3 LT315/75R16, BF Goodrich Mud-Terrain T/A KM2 (BFG24970) Barely broken in--these tires are like new.
* Tyre Iron Deluxe 23" long double sided and Tyrepliers beadbreaker. Adjustable from sizes 4" to 19.5" in diameter
* EEZI Awn Globetrotter tent. 4 sidewalls with windows, bug mesh, door. Integrated, self-supporting retractable awning. Separate floor (in vestibule section). Bed size 79" x 63" with 3.3" thick mattress and a memory foam pad. Tent is mounted on Thule Rack Load Bars with Adjustable Track. Tent has been used 6 times and is in excellent condition.
* Chaser Tail gate 16" x 32" with locking T-handle
latches. This rear door allows access to trailer with tent up or for getting to items in the very rear of trailer cargo compartment.
* Custom Swing away spare tire carrier by Scott Brady; swings out of the way to allow access to the tail gate.
* Lock-n-Roll 6000 lb Lock-n-Roll Articulating Coupler with Silent Pin Aero Silent Hitch Pin.
Always garaged when not in use.
The trailer new was $19,461. Your cost… $12,500
Come get it...
cityblues
Thanks Marshall, I forgot all about posting that. Glad you're back safe and sound ... with the trailer, too. Looking forward to hearing about great adventures with the Chaser.
WonaWarrior
