So here's an update. The water project kept growing into other additions so took me a bit to get this far.
I needed power for the pump, and I had power going to the canopy. I also wanted to change the existing light in the canopy( very poor output). I already had a double cigarette lighter style plug mounted. I wanted to run one of my inverters back there as well. So I came up with this.
It is a deep junction box from HD. I ran the power into it, put a ground bus bar(? I think that's what it's called) and a fuse block. From that I ran direct power to the inverter( it has an on/off switch) and to the cigarette plug. I then ran switched power to the pump and to the lights. Just finished the first install and test tonight and all work.
The lights really light up the area. Here's a shot with the new LED lights I installed under the bumper as well. That switch is in the cab.
As for the water pump, right now I'm gonna use my 7 gallon jug. It will sit on its side but upright. Gravity will feed water to the pump( which I mounted on the bottom side of the shelf) still working on finalizing this part now that I have power and it works. My plan is to run a garden hose out. Long term plan is get a bigger tank if needed.
Tomorrow I will attempt to finish it all up and clean it up.will let you guys know how it works.
I also got my front receiver installed. No pics yet, but it doesn't look too bad.
