Rigidity comes from 2 things: Mass, and shape. Expanded metal has little of either. Would it help maintain the shape of the basket? Yes.
Will it add carrying capacity to meet the needs of a 100+ lb dynamic loading situation? Not in the least.
Sorry to burst your bubble, but you are wrong. Honeycombs, very little mass, very strong rigid structure that has been repeated over and over again in structural design, for example... the original idea behind creating expanded metal.
To be clear, there are different versions that have varying degrees of strength. True expanded metal is stronger than the original sheet it came from and the joints are stronger than a weld or wrap would be. Perforated metal, holes have been punched and the joining areas weakened, so not ideal for structural use, but it looks pretty and is used a lot in design. And then it gives expanded metal a bad wrap when it deflects and fails.
Wire mesh, well, yeah, no need to explain.
So is expanded metal used purely by itself to hold heavy loads? Well no, that wouldn't be very smart, but as I said previously, I will also be modifying the subframe of the rack...
So, back to my build thread.
I'll update more once I get some time to modify the rack.
