That really wasn't my question.. I want to know if 5000btu will cool my cab
I understand about the desire not to add an aftermarket AC. Makes a lot of sense if the top or back of your cab is suitable for mounting the evaporator.
Sad to say, but the fact that a 5,000 BTU air conditioner will cool a bedroom is not really relevant. Freightliner had their ads make the point that their cab ACs put out enough to cool a 2,000 square foot house. Most automobile AC units provide 10-20,000 BTUs of cooling, and most over the road trucks are 20-40,000. Also, figure that one 13K BTU roof top unit is routinely used to cool about a 25 foot motorhome, two for a 35 footer, three or four for a 45 footer. Also, it takes about 10,000 BTU to cool an insulated Sprinter van, and most of the units sold to cool truck sleeper cabs overnight are 7-10K. The smaller Red Dot rooftop unit is 16K.
A lot has to do with the size of the cab and the amount of windows. For something the size of a regular cab pickup or the cab of a LCF truck, 5,000 BTU it might work in reasonably temperate climates with assuming not much solar gain. For something like a big crew cab pickup, or something with a lot of sunlight getting in, it'll probably fall short.
The other issue is the difference between keeping a reasonable temperature and getting there in the first place. Leave the cab in the sun for a couple of hours and you could end up with the inside getting to 130 degrees. It would take a 5,000 BTU AC many hours to get the space cooled off.
So depending on the vehicle, the ambient temperature, the amount of solar intrusion, how long you need to keep it cool and so on, 5,000 BTUs could possibly do the trick, but it seems much more likely to me to be too little than too much.
