walley_eye
I have run into the electrical nightmare I didn't want in buying a used 2012 F-150 XTR 5.0L 4x4 w/ factory tow package.
This nightmare first began this year after it had rained outside.
After starting up the truck in the driveway the dash showed the battery light. Then it got worse.
We took the truck in to a Ford dealer and they replaced the alternator. Well that turned out not to be the problem.
Now whether it's sitting in the driveway or driving the whole dash will die out then come back binging, showing the battery light and the radio cuts out with it. Sometimes the radio and climate control cuts out while the dash still works and then comes back and then the dash and radio go all haywire cutting in and out. Every time it does this I hear a click from the computer behind the kick panel, but the wife says it's coming from under the dash.
It's been back to the dealer twice now and the last time they said they took out and took apart the harness checking it for water and or corrosion and found nothing. Then the mech said he found the problem in the computer by the passenger side kick panel saying the harness wasn't plugged in all the way. That made no sense to me but ok.
Turns out that wasn't it either and the problem continues. So back to the dealership it goes Monday.
Worst part is the Ford Factory warranty is over(was shocked to find out it's only a two year warranty) so this is covered by my extended warranty I bought with the truck from a private insurer.
Any ideas?
Here's a video to show what we see on the dash. https://vimeo.com/130046698
Sent from my Grizzly 700 somewhere in the Canadian wilderness.
Any ideas?
