Thread: 24 volt to 12 volt?
  1. #1
    Join Date
    Apr 2007
    Posts
    324
    Default 24 volt to 12 volt?
    When using a military trailer set up for a 24 volt vehicle, what needs to be done to run ito of a 12 volt system? Just new bulbs or do they work fine as is?
    The Goat, '73 Series III coil conversion, PS conversion, Daihatsu 2.8 TD,dual ARB's etc. SOLD
    '97 Toyota LC, getting built
  2. #2
    Join Date
    Aug 2005
    Location
    Calgary, Canada
    Posts
    3,886
    If it's just lights, switch the bulbs over to 24v and you're done. Electric brakes are a different story.
    Edit: Hold up. I'm not clear... is the tow rig 12v or 24v?
    Pete Hartl - VE6PGH - 0VRLAND
    EXPEDITION = (Encounters + Adventures + Experiences) x YOU
  3. #3
    Join Date
    Jun 2006
    Location
    Park City, Utah
    Posts
    3,382
    Yep just bulbs. I think you can get away with running the 24 volt bulbs but they run dim... I would swap them out personally... If there is anything "complicated" like a battery box on there or electric brakes or anything (doubtful) then I would avoid running that stuff 12V... The world would be about 25% better if the entire automotive world was 24V in my opinion...
  4. #4
    Join Date
    Apr 2007
    Posts
    324
    I have been corrected on another forum that my trailer should already be 12 volt as only Brit radio vehicles were 24 volt.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
