Not much has been done to the rig. Just been living and working out of it mostly. Things break, they get fixed. but it's kinda done, and haven't needed to add anything to it in the last couple years.
Had a fusible link burn up on the firewall. Spent hours tracking it down.
Turned out to be a blown diode that was taped and inside the wiring harness in middle of firewall. This controls the water in fuel light on the dash. Very difficult to locate and no info about it's location in any of the manuals.
Was on the way back from Ontario when the truck started making horrible clunking noises coming from the rear. Popped the cover in an Arby's parking lot and found this surprise. Pulled out what I could, brake cleaner in up and around, poured new gear oil in and drove it 500 more miles cringing at all the popping and grinding it was doing.
Turns out a bunch of teeth broke of inside the locker.
Thankfully, all the damage was kept inside the actual locker and the axle was not trash.
Cleaned up the insides and all was well.
Unfortunately, I had to dish out the cash to get a new locker...
Luckily I have all the tools and knowledge to do these things. Well, maybe all the tools, working on the knowledge part. Also, don't let anyone ever tell you that you don't need a vise big enough to put differential carrier in.
Good to go. It's been a year and everything has been working fine.
