Thread: Roof Tent Mounting Options
  1. #121
    Join Date
    Jan 2011
    Location
    Newberg Oregon
    Posts
    275
    Thank you,
    How you are enjoying your travels
  2. #122
    Join Date
    Feb 2008
    Location
    Oceanside OR
    Posts
    215
    You know, I was thinking, Thule xSporter is an excellent system but it is a little pricey and you may not need the versatility is offers. If I were doing this I would probably go a slightly different path.
    What about something like this?
    This is an ancient Maggiolina on an old Can Back system. It offers a nice feature that you can keep equipment in the back protected and shouldn't be that much more than the Thule system. I sadly can't recommend Can Back, don't think they are around anymore, but there are a bunch of clones like Best Top that should be able to do a better job.
    Here is a link to the article
    http://www.4wdandsportutility.com/ne...ent/index.html
  3. #123
    Join Date
    Jun 2009
    Location
    New Hampshire
    Posts
    20
    Someone was looking for a pic of a RTT on the roof of a DC Tacoma......Here you go! Probably looks kinda weird, but its an effective mount and doesn't cost an arm and a leg. That and I can still carry my bikes in the bed or use the hard tonneau cover for bed security.
    I just remounted it for the season yesterday and added a few touches to help keep it more secure and quite. It does sit directly on top of the towers and that concerned me as well. To fix it (I think) I took some rubber material (actually an old thule foot pad) and cut it into pieces which I then glued to the top of the towers for the RTT to sit on. Also, I added steel spacers (about 3/16") directly under the mounting rails for the RTT. I have only driven around the block since making those modifications, but already it seems way more quiet than previously.
    Attached Images Attached Images
    07 Tacoma TRD DCab 6 speed, 265/75R16 BFG ATKO, bilstein 5100 in front,Toyota TSB rear with 1" long block by Silly Fab, Autohome Maggiolina Extreme, Paid off!!!
  4. #124
    Join Date
    Jun 2011
    Location
    Pennsylvania
    Posts
    2,126
    I made several brakepress bent 1/8" stainless steel gutter mounts that bolt to the bed lip under my tonneau cover.
    I use thule bars with gutter mount towers. Works great, removable, and stealth without the bars on.
  5. #125
    Join Date
    Jan 2011
    Location
    Newberg Oregon
    Posts
    275
  6. #126
    Join Date
    Oct 2009
    Location
    Salem, Oregon, United States
    Posts
    560
    Quote Originally Posted by mike r View Post
    Nice setup Mike
    Nik "Nikson" Orlov, Jr.
    '06 Jeep Wrangler Rubicon Unlimited "ATAMAH"
    Build Thread
    '01 Jeep Cherokee XJ "Ronin-I"
    Build Thread
    YouTube Channel
  7. #127
    Join Date
    Mar 2010
    Location
    Fresno, CA
    Posts
    221
    Quote Originally Posted by Mike S View Post
    Suggestion -- if you haven't already, check ut the Thule Xsporter rack - mounts to the bed rails, adjustablehe for height. A very good solution for many people.
    Mike, We have a medium Maggiolina to mount a ARE shell on a short bed Ford Raptor.
    Question: Can we directly mount to the shell with out bars? Will the hurt the tent since it wiil not have the cross load bars? I will have to spacers between the tent and shell so it clears the cab.
  8. #128
    Join Date
    Feb 2008
    Location
    Oceanside OR
    Posts
    215
    Fresno, I've put some tents directly on shells, mostly Columbus' like Mike's because of the height. They will cut a trap door in the bottom of the tent so they can have the added height to change into gear like wetsuits away from the wind. Normally I do not recommend it because your tent will outlast many vehicles, mine has gone through about four, so you want to be able to move it easily to other vehicles. They are a very high grade fiberglass so you can modify or patch them with epoxy resins and the repair is stronger than before.
    An aside, the tents are really aerodynamic and it seems to be just as efficient, drag wise, to mount the tent on bars. The air gap seems to add a little downforce.
  9. #129
    Join Date
    Mar 2011
    Location
    San Clemente, Ca
    Posts
    227
    I was going to use the X-sporter to mount my ARB, but the cost of the rack plus the bed rail system adapters was more than buying a rack from All-Pro. Since All-Pro is an easy drive from me I could save the cost on shipping. Plus the rack could be drilled to mount my pioneer gear and high lift. So...
    Something to look out for is the location of the front spring steel rods that hold the window shades open. Depending on where your tent goes and how high the rack is they may interfere with the roof line of your truck. The rods need to be inserted parallel to the tent base then bent up to the window shades. Where my tent is mounted, it is difficult to insert one of the rods due to the roof line. Below you can see the closest rod is inserted parallel to the tent and the rear is in the up position. Its easy to see that inserting and removing the back rod without leaving deep scratches on the roof takes some practice.
    The All-Pro APEX rack is a good solution for tent mounting. Its heavy but will hold up to anything.
    "MEN WANTED FOR HAZARDOUS JOURNEY. SMALL WAGES, BITTER COLD, LONG MONTHS OF COMPLETE DARKNESS, CONSTANT DANGER, SAFE RETURN DOUBTFUL. HONOR AND RECOGNITION IN CASE OF SUCCESS."
    Ernest Shackleton’s ad placed in the London papers, recruiting members for his
    1912 Imperial Trans-Antarctic Expedition.
  10. #130
    Join Date
    Mar 2010
    Location
    Fresno, CA
    Posts
    221
    Quote Originally Posted by Lemsteraak View Post
    What is my concern is this part of the instructions:
    "Before placing the roofbars on the vehicle, check the bar length and attachment strength.
    Bar length "L" shall not be less than:
    Small: 124 cm or 49 inches
    Medium: 142 cm or 56 inches
    Large: 160 cm or 63 inches"
    "Again, make sure your roof bars are not too short"
    If I mount on spacers to the shell will I break the tent? Does it require the horizontal bars to reinforce it?
Page 13 of 15 FirstFirst ... 31112131415 LastLast
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
