Retired Tanker
I started this thread in "Vehicle Mods," and got a recommendation to repost it here.
So, after looking at many, many fine works of craftsmanship, I still had a few lingering concerns over the various approaches to drawer slides. The skate bearing is obviously the way to go, so that's a no-brainer. But after looking at so many designs, I noticed the loss of volume due to the intrusion of the various bearings, bolts, and associated hardware. Not to mention the space under the drawers.
While musing about a more efficient approach, my wife asked me to move a rack in the oven...and Ka BLAM!! It hit me.
Below is a design the moves the bearings below the drawer and into the deadspace created by the bottom brace. It spaces the bearings in a logical fashion with more bearings near the front to support the extended drawer. The key is a short piece of channel steel that will fit between the rear-most bearing and the next one forward, but as the drawer is pulled out and passes the "tipping point" it rests on an increasing number of bearings. This also acts as a "stop" to keep the drawer from being pulled all of the way out. To remove the drawer, empty it, push it all the way in, and then slowly pull is out while trying to tip it forward. When the channel steel passes the rear-most bearing, it will lift clear and you can pull the drawer out. Obviously the sides of the drawer will have to be short enough to allow this.
By putting the bearings at the bottom of the uprights, you have less chance of bowing due to carrying the weight.
Below is the original layout, and then a couple of sketchup views:
