FS - Montero Gen2/2.5 Front Seat Parts & other Misc items
nckwltn
**Updated 12/1
Moving in a few weeks, don't want to take any of this with me.
Prefer local pick up, zip code 91344, but will ship at your cost. Link to higher quality photos: https://goo.gl/photos/2Px8sxPfyLGfUgmM7
PM me if you want something, post to the thread with questions.
SOLD - - 2 bouncy seat bases. Will bolt straight into a gen 2/2.5, but you will need manual seat bottoms from gen 2. The adjustment knob on the driver's base is broken, but can easily be turned with pliers. You won't use the adjustment knobs after you get it set where you want anyway. These will not work with Gen 2.5 power seat bottoms, and will not work with the gen 2.5 passenger seat with the utility tray under the seat.
Driver's Power Base Sold
$10 - passenger manual seat base for gen 2.5. Driver's seat base is power, and everything works (have tan trim pieces as well, not pictured) Passenger side has drawer under seat. great little storage area. Passenger seat is manual adjustment (have blueish trim pieces, not pictured). Probably worth the $20 bucks just for the tray that goes under the passenger seat (see photo link above for picture of tray). These came out of a gen 2.5
$30 for pair, $20 each - Upper seat backs. One is driver one is passenger. These will work on manual or power seat backs (foam may need a small trim for power seat back, as these came from manual seat back). These are bluish in color and are in very good condition.
Driver's side spoken for - $20 for pair, $15 each - Passenger and Driver's arm wrest. Same color as seat back, some wear, but not all torn up like most I see at the scrap yard.
$20 for pair, $15 each - Headrest for seat. Should work in gen 2 and 2.5. If you buy a seat back, I'll throw the corresponding headrest in for free, assuming that someone hasn't already bought a headrest individually. Same color as seat, and in really good condition.
$10 - Seat bottom from Gen 2 passenger manual seat. Bottom is in good condition, with one small cut in leather (pointing to it in picture)
Photo: Click link to more pictures above, can't seem to attach photo.
$10 - Rain gutter trim from Gen 2.5. Will probably fit Gen 2.0 as well. Chrome is in good condition, will be difficult to ship.
Free - Gen 2.5 factory roof rack. One of the bolt holes is wider than the factory bolt, as the factory bolt pulled through the plastic. Might be helpful to have an extra 2 cross bars. Don't have the rubber spacers that went between the feet and the car roof.
Free - Seat back frames. Passenger is manual, driver's is power. Should be compatible between the Gen 2 & 2.5. Motors work in seat back. Also have the panel that goes behind the seat back with the storage-pocket.
Free - Gen 2.5 seat cushions. One driver side, one passenger. Both are in good condition, driver's side is worn from getting in and out of vehicle. Pulled from vehicle with ~145k miles. Driver's side is for power seat. Passenger side is for manual seat and will work with Gen 2.0 manual seat bottom.
WonaWarrior
