What roof rack lights do you run?
kojackJKU
Autism Family Travellers!
I have 33s and yours like like 4" higher than mine. must be the angle of the pic! You should install HID into your hellas....Its a worthy upgrade I tell you that!
kojackJKU
RIght on your rack. The ones I used lived on my Pat rack for a full winter, now they live just inside my JK's grill. The ones from VVME are fine to be open to the elements.
TeriAnn
I'm running 4 Hella 3000s with 100 watt bulbs. The two inner ones have a narrow beam and are pointed straight out and the 2 outer ones have a wide beam and are pointed to fill in the sides where the inner ones start to leave off. They are mounted to the underside of my roof rack so they are protected from branches. You can sorta see them in the picture. :)
rayra
Here in the Arizona sun the shells have chalked up a bit, but functionally not an issue. I bang low hanging limbs with these all the time.
Back of lights showing sun fade on shell.
[/URL][/IMG]
Please tell me you're blasting Die Walküre / 'Ride of the Valkyries' on that speaker.
WonaWarrior
