Wiring
N / A
From all I have read it seems it is recommended to wire mobile radios to direct to the battery, and it is said to wire the ground directly too to prevent any interference. I want my radio turned off when the truck is off, so I was going to use a relay for this, doesnt seem that many people go this route, is there an interference issue with relays as well?
155mm
It shouldnt be an issue, as the relay just opens/closes a connection based on the energy from a different circuit. It doesn't connect the two circuits.
A mechanical relay won't cause issues as long as your radio is OK with having the power shut off out from under it.
I've got a Uniden scanner that runs off a SD card. It tends to corrupt the SD card if I unplug it while it is on.
kj4vyi
shouldn't be an issue just use a good 30amp relay (bosch ) good connectors and wire it into an accy line ( if its easy to get to your radio use the accy line from it into the relay ) and ground it - instant switch for your radio
prerunner1982
It will work, but may I ask your reasoning?
A radio on receive won't draw enough to drain your battery and being able to turn the radio on without having to turn on the vehicle can be nice.
pugslyyy
Yeah I actually like being able to leave my radios on when on the trail but out of the vehicle.
brentbba
This! ...and I have both truck and commuter car radios wired direct to the battery with 15 amp fuses on both positive and negative wires at the battery.
unseenone
Short protection. 857d draws about 1/2 amp, a little more when actually receiving a transmitted signal. It is hardwired to 2nd battery circuit, but not right to the battery. If you have a radio with APRS, then you might want an auto-shutoff circuit, so when you turn off the truck, the power goes off.
The PWR Guard plus might do the job.
https://powerwerx.com/fuses-circuit-protection
unseenone
Cool web site pugslyyy
This is a hotly debated topic I guess. I did it with both fuses, radio also comes that way. Installer preference will prevail. OALAEGOATAS
http://www.arrl.org/forum/topics/view/115
Should I add a fuse on the negative lead from 9-120AH battery?
Mobile radio installs - should I run the negative lead from radio to chassis, or to battery? should it be fused or not?
(Most mobile radios include a fuse on both positive and negative leads - I think this a holdover from years ago when commercial installs used positive ground radios so included a fuse on negative
lead, not knowing what type of vehicle it might be installed in).
I'll clarify my post, and explain further. I have a 75 amp run from the engine compartment to the rear of the vehicle. Both Positive and Negative are fused AT THE BATTERY on that line. If there is a short to body or another ground, to the positive the fuse will blow at the battery, to reduce the chance of a fire. The fuse on the Negative would do the same thing, which is protect the ground, if a short developed from a hot line to the ground.
The Ham Radio I'm using has both fuses in the factory cable. Picture of power cord here.
http://www.radiospecialists.com.au/Radio Power cables.htm
wirenut
If you ground directly to the battery and the main negative cable to the vehicle comes loose then the entire vehicle will try to "ground" from your antenna mount, down the coax, thru the body of the radio, and thru it's negative lead. You don't want this to happen. A fuse in the negative lead prevents this. Or, grounding near the battery on the chassis right where the main factory negative lead grounds get's you a direct connection but doesn't put the radio in "parallel" with the main negative lead if it comes undone.
pugslyyy
Okay.
RobRed
I have a system of relays to power up my radios. I dont run them to the aux battery directly but to a blue sea safety hub 150. Yep I break all the rules. But on the flip side I have a toggle switch for key out power up of comms and power off with ACC (the key).
WonaWarrior
