...and I'm finally done with the 60k service (I think/hope). drag link done, tie rod done, suspension pins and bushings done, all 4 hubs done, all fluids changed (crank case, transmission, transfer case, front diff, rear diff).
I've eyeballed the alignment, and will check it again once I put the wheels back on the ground.
The two biggest issues were servicing the rear spring pins (because they had never been, the service body boxes are actually in the way) and I had to put the tie rod on my lathe and trim a quarter inch off each end so that the aftermarket (greasable) tie rod ends would fit.
Will it make any difference? Who knows, but I feel better having looked at everything. Both hubs on the passenger side were too loose, and both hubs on the driver side were too tight. Hopefully, like Goldilocks, they are all "just right" now.
