We're one step closer!
The washers worked beautifully. The engine now runs smooth with no bad noises.
Upon further investigation, the alternator voltage regulator was bad. I replaced the alternator this afternoon but had to transfer the capacitors. Despite the new alternator, the tach is still not operating. Wondering if the capacitors have anything to do with this?? Other thoughts?
Also, the o2 sensors may not be working. Both were new, however, the plug coming from the truck on the driver side was damaged in the form of the wires having been pulled out of the plastic housing. I tried to repair by putting the wires back into the clip but I don't think it is working. Assuming I'd be better off finding a replacement plug to cut and splice into then try again?
Perhaps the tach and 02 sensor and engine not running as powerful as it should be are related?
In other news, my brake lights and reverse lights are suddenly not working.
Blinkers aren't working either but those haven't been working for a while, despite swapping out the blinker switch unit.
Thoughts on either of these matters?
You guys have been a tremendous help with all this weird little stuff that I've run into. I very much appreciate your insight and experience.
On the one hand, I have a lot of frustration because of the guy leaving me hanging and the botched engine job that I've had to finish. On the other hand, largely because of your assistance, I've been learning a hell of a lot with regard to maintaining the Classic.
Here's a photo from the test drive around the farm yesterday.
