Park in the sun. Put like a 20a load on the batteries.
That will consume all that your solar can produce plus a bit more, and then you can see exactly how much the solar produces when maxxed out.
Engage the split-charge relay by turning on the key without starting the engine. Turn on everything in the truck - headlights on high beam, radios, heater fan, etc. That should probably be enough load to soak up all the solar can produce.
With an ACR, force it on with the engine off and do the same thing.
