Page 6 of 6 FirstFirst ... 456
Thread: New Commander
  1. #51
    Join Date
    Sep 2005
    Location
    Tucson, AZ
    Posts
    935
    Quote Originally Posted by expeditionswest
    John,
    The new electric version of the Jeep lockers will send 100% of the power to all tires.
    After seeing a few Commanders at SEMA with some mods, I am warming up to the platform. I also sat in one, and spent some time in it. The interior is very nice, and has good ergo.
    Just looked over specs and info on the Commander? Nowhere could I find that Jeep states the diffs are locking. They say they are electronically controlled LSD's. That's not a locker. ???????
    NEW: My 100-series (Roklimo) step-by-step 5-year buildup:
    http://expeditionportal.com/forum/showthread.php?t=6022
    1997 Lexus LX450 "Trailex"
    Website: http://shottscruisers.smugmug.com/
  2. #52
    Join Date
    Nov 2005
    Location
    Boyertown, PA
    Posts
    1,685
    Quote Originally Posted by ShottsCruisers
    That is correct. The Wrangler Rubicon is the only Jeep model equipped with a differential that provides a 100% lock.
    I watched them demonstrate their "Quadradrive" (or whatever its called) system during the debut of the WJ Grand Cherokee platform. On a closed course, they drove the Grand Cherokee up a slight uphill grade. Small roller platforms were strategically placed in an alternating manner so that only one tire on each axle would have positive traction during ascent. As soon as the Jeep encountered the rollers, it would lose traction and stop for a second - but then the drive power would visibly redirect to the opposing wheels on each axle, and the Jeep would continue with relatively little effort.
    Certainly not a locker - more like a glorified LSD, but it still seemed relatively effective. Seemed a bit more intelligent than a plain old LSD.
  3. #53
    Join Date
    Jun 2005
    Location
    Prescott, AZ
    Posts
    12,810
    The differentials in the quadra-trac II use 12v electricity to lock the clutches electronically in the differentials. The locking effect is variable from 0-100%.
    I have their technical engineering specification.
    This is the same type of system used in the LR3.
    I will say though, that the holding power of the magnetic clutch must have a limit, so fitting larger tires, or certain terrain charactoristics would likely result in the clutch sliping. Physics are what they are...
    Scott Brady
    Overland Journal
    D1 | LJ78 | LR4 | MKIII | J8 | G-Wagen |
  4. #54
    goodtimes's Avatar
    goodtimes is offline Expedition Portal Moderator Expedition Poseur
    Join Date
    Jul 2005
    Location
    Tucson
    Posts
    4,897
    I'd be interested in seeing that someday Scott...assuming it is not covered under a NDA.
  5. #55
    Join Date
    Sep 2005
    Location
    Tucson, AZ
    Posts
    935
    Exactly my thought.
  6. #56
    Join Date
    Jun 2005
    Location
    Prescott, AZ
    Posts
    12,810
    Commander gets the 3.0L diesel for the 2008 model, early 2007 release.
    26mpg reported, 376ft. lbs.
    Scott Brady
    Overland Journal
  7. #57
    Join Date
    Sep 2005
    Location
    Tucson, AZ
    Posts
    935
    I hope the diesel trend continues.
  8. #58
    Join Date
    Nov 2005
    Location
    Conway, Arkansas
    Posts
    1,119
    Meee toooo.....
    When life gives you free time, grab a map and go.
    Member #146
    Former Fat_Man
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
