Not saying I've measured them myself and there are many mistakes on the website, but according to Ramtruck.com under the specs:
- 3500 CC Reg Cab 4WD 167.5 wheelbase, turning circle 47.9
- 2500 Crew Cab Long Bed 4WD 169.4 wheelbase, turning circle 53.2
- 4500 CC Reg Cab 4WD, 168.5 wheelbase, turning circle is 47.9
- 4500 CC Reg Cab 4WD, 204 wheelbase, turning circle is 57.2
Do those numbers make sense? I don't know, sorta kinda?
Does 2" of wheelbase between my truck and a long bed crewcab increase the turning circle by 5'? Seems a little odd, but I can tell you my truck seems fine to drive around for a camper, not as nimble as my traybed single cab 140" but I wont be taking the camper to the same spots that things been...at least not a few of them
As far as I know there are no lockers available for the Magna front axle or the rear axle in the 4500/5500.
dh
Yes, it makes sense, because the wheel cut (number of degrees the wheels can turn sharply from center) is greater on 4500 chassis cab than on the 2500 crew cab. The five extra feet in turning circle required by the 2500 isn't due to the less than 2" increase in wheelbase on the 2500. It is far more likely due to the 15 degree (just a guess) increase in wheel cut in the wider front axles of the chassis cabs that accounts for the 10% reduction in turning circle. But then again, if your 3500 CC SRW has the exact same standard axle as the 2500, my reasoning wouldn't make sense in that case, would it.
So let's look to the suspension... my understanding is that the front suspension for 4WD is different on the chassis cabs (four/five link carryover) than it is for the 2013 up pickups (3 link that copied Ford's long radius arm front set up). If axle width is indeed the same, and if the suspensions are different, then maybe one suspension type affords more wheel cut than the other. If the axle width AND the suspension styles are the same, and the width and wheel cuts are verified as the same with actual measurements, rather than visual guesstimations, then I would be just as suspicious as you are about the accuracy of Ram specification data. Ford makes the same kinds of mistakes in their Source Books.
Full disclosure... my chassis cab is a Ford, not a Ram, so the personal experience and knowledge I have is more based on Ford.
However, both Ford 550 and Ram 5500 chassis cabs have used the same Dana S110/S111/S130 in years past. And Dana offered a factory option helical gear TrueTrac limited slip option for this banjo housing, welded cover plate, square tubed, drop in third member axle family. (The new 2017 Ford chassis cabs use Dana's new M300 round tubed, cast housing with bolted cover axle family in the rear). The front axles are indeed different, and I know nothing about Magna axles, only Dana.
