Page 1 of 2 12 LastLast
Thread: tire pressure tool
  1. #1
    Default tire pressure tool
    could anyone recommend a dial type (not digital) tire gauge? something of quality maybe going from 0 to 100 psi?
    thanks
    j
  2. #2
    Join Date
    Mar 2007
    Location
    The Nanny State
    Posts
    5,726
    What I have is something similar to this HF part. I have previous model from when it sold for $9.99
    I really like the in-line chuck instead of the more common angled chuck. I found a better version of them in a NAPA catalog, but have not ordered any yet. I ditched the near worthless gauge and got a decent one from McMaster like p/n 4003K11 ($18.71)
    I bought one for each rig, but so far only one has gotten the gauge upgrade.
    I used to swerve around my hallucinations, now I drive right through them.
  3. #3
    Join Date
    Jul 2006
    Location
    Roxborough, Colorado
    Posts
    836
    Currie EZ tire deflator. You can check tire pressure and air down quickly if needed. Cost about $30 for the Currie model. ARB has what appears to be a direct copy of it as well.
    "If there must be trouble let it be in my day, that my child may have peace." Thomas Paine
    2003 Toyota Tacoma DBL Cab TRD
    2007 Adventure Trailer Chaser
    1987 Toyota 4runner Turbo
  4. #4
    thanks; i'll check them out
    j
  5. #5
    Join Date
    Jul 2008
    Location
    Georgia, USA
    Posts
    2,994
    http://www.ghmeiser.com/
    Available at many autoparts stores.
    Even from Amazon
    http://www.amazon.com/s/ref=nb_ss_gw...auge&x=11&y=21
    Tom Rowe
    Four wheel drive allows you to get stuck
    in places even more inaccessible.
    62 88 reg
    67 NADA x2
    74 Air Portable - The Antichrist (tag 6A666)
    95 D1 5-speed
    95 D90 5-speed
    97 D1 Automatic
  6. #6
    Join Date
    Aug 2006
    Location
    Face of the Sun... Mesa, AZ
    Posts
    707
    We have had a lot of good feedback from the ARB tire deflator.
    It is corrosion resistant brass/stainless deflator tool, protective rubber gauge guard and easy to read dial with 1 PSI increments.
    It is a good one to have while deflating so you know exactly where you are pressure wise.
    Sierra Expeditions
    Outfitting for the Overland Traveler
    Sierra Expeditions
    www.SierraExpeditions.com
    1-866-507-4254
  7. #7
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    4,776
    Quote Originally Posted by FlyingWen
    Love mine!!!
    Very quick too....And i have 6 tires to play with too!!!
  8. #8
    I used the ARB deflater and found it to be cumbersome for use on the trail. I soon gave it away. I guess it depends on whether you want to measure tires as they sit, measure pressures while deflating, or while inflating. I would far prefer the combination gauge and inflater mentioned earlier (whether from Harbor Freight or not would be up to you), attached as an air chuck to the OBA system. I generally find it is far easier to deflate tires with a simple stem tool and pencil gauge than to attached and fiddle with a deflater/gauge, and easier to make fine adjustments down to the pressure I want with a pencil gauge. Airing up, however, is far easier with a gauge/inflater than with chuck and pencil gauge because you can quickly monitor pressure as it rises, so you don't have to detach hose, read pressure, reattach hose, try again.
  9. #9
    Join Date
    Nov 2007
    Location
    San Diego, CA
    Posts
    1,097
    Ultimate Air makes a good one.
    It's a little pricey ($59), but it's the only one I've seen that has reasonable scale. It reads from 0 - 60psi. If all you're using it for is tires, this should be the most accurate.
    http://www.ultimate-air.com/Inflator...i_p_11-27.html
    ~Jamie
    2000 Tacoma TRD 4WD PreRunner
    Supercharged, Locked, Armored.
    Mountain - she can crawl it.
    Butt - She can haul it.
    My Rig
    My Trailer
  10. #10
    Join Date
    Jul 2008
    Location
    Georgia, USA
    Posts
    2,994
    I bought my first Accugauge in '81 and still have it, and find it still accurate. It's available in 15, 30, 60, 100 and 160 psi ranges.
    I also have one with a dual chuck end on a rubber hose
    Tom Rowe
    62 88 reg
    67 NADA x2
    95 D1 5-speed
    95 D90 5-speed
    97 D1 Automatic
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
