Page 1 of 2 12 LastLast
Thread: Roof double wall question. Gap between steel panels?
  1. #1
    Join Date
    Jun 2005
    Location
    Prescott, AZ
    Posts
    11,879
    Default Roof double wall question. Gap between steel panels?
    Hey all. I am installing my drop down VGA navigation/computer screen in the ceiling, and need to know how much space there is between the two roof panels. The roof is double wall, and I don't know the gap to allow for the screws.
    Someone that has drilled for a roof mounted CB antenne would know.
    Thanks so much!
    Scott Brady
    Overland Journal
    D1 | LJ78 | MKIII | FZJ80
  2. #2
    Join Date
    Sep 2005
    Location
    Tampa,Florida
    Posts
    1,994
    Hmm is it double on the roof? On my reg cab it is single as far as I can tell. Guess they do it different on the D-cab. Are you talking about where the suppot pillars run across the roof?
  3. #3
    Join Date
    Jun 2005
    Location
    Prescott, AZ
    Posts
    11,879
    I am pretty sure the entire roof is double wall, but the two panels run closest towards the midline.
    But I could always be mistaken... If that is the case, I am going to have to weld nuts up there... More work...
    Scott Brady
    Overland Journal
  4. #4
    Join Date
    Aug 2005
    Location
    Mesa, AZ
    Posts
    5,265
    Quote Originally Posted by expeditionswest
    Talk to Got Cope over at TTORA's national boar. He has a CB mounted to the roof of his TACO he would know, IF not MIKE or AK TACO would know.
    Wil Kuhns KF7CDH
    Sierra Expeditions *Forum Sponsor*
    The only regrets in life are the risks you didn't take.
    Mod Progress Gauge:[||||||----] = 60% Complete.
  5. #5
    Join Date
    Aug 2005
    Location
    San Diego, CA
    Posts
    863
    Scott,
    My 2000 Tacoma is single thickness roof with metal ribbing & interior liner. My antenna is mounted close to the interior dome light which I removed for working access.
    Member #50
    Always ready to go.
    2000 Tacoma.
    KG6SGM
  6. #6
    Join Date
    Jun 2005
    Location
    Prescott, AZ
    Posts
    11,879
    Thanks Al, that is helpful.
    I think this is going to be a bigger job than expected Oh well, most of them seem to go this way.
    Scott Brady
    Overland Journal
  7. #7
    Join Date
    Aug 2005
    Location
    Mesa, AZ
    Posts
    5,265
    Scott-
    If it is a single wall roof, you might be able to mount it by using some exopy or JB weld to adhere some nuts to the roof. I am sure that a tack weld would burn the white paint on the other side of the roof, but hey who sees the roof anyways?
    Another option to mount the monitor might be to fabricate a bracket using the existing screw holes for the visors, and rearview mirror/light assembly, and the over head lights assembly aand make your own double wall.
    (I am assuming you are puting it up in the location of the rearview mirror location.) Just some ideas which I am sure you have thought of.
    I am looking into a visor option to put on my list of mods, but am not sure if I want to block the view a head. My other option I have been playing with is in the stock radio location, either double din or a single din flip up. But hey its down the road a ways.
    Well let us know what you come up with... I am sure interested in this one!
    Wil
    Wil Kuhns KF7CDH
  8. #8
    Join Date
    Jun 2005
    Location
    Prescott, AZ
    Posts
    3,027
    Scott, I have a link that may help - but the page is no longer around, so I found it using the wayback machine.
    Ronn's monitor install on a 1998 Xcab Tacoma.
    Give it a try. If some of the pics time-out and do not load, right click on them and "show picture" - I got some to work that way. It looks like Ronn actually welded some bracketry to the OEM framing to make it work. (He also mounted a VCR to the rear ceiling)
  9. #9
    Join Date
    Jun 2005
    Location
    Prescott, AZ
    Posts
    11,879
    Perfect.
    That is what I am going to have to do... Break out the welder baby
    Scott Brady
    Overland Journal
  10. #10
    Join Date
    Aug 2005
    Location
    Mesa, AZ
    Posts
    5,265
    Scott did you see this post over on TTORA? IT might help you out..
    http://www.tacomaterritory.com/forum...1&postcount=12
    I am also sure that there has to be one guy over at custom Tacos that has done this too... might want to post up over there and see if they give you some good feedback. Some of them install these thing for a living.
    Wil Kuhns KF7CDH
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
