Page 1 of 11 123 ... LastLast
Thread: F 450 flatbed camper build
  1. #1
    Default F 450 flatbed camper build
    Where is the correct forum location for a flatbed, camper build on a F-450? I will wait until I get an official reply.
  2. #2
    kcowyo's Avatar
    kcowyo is offline Expedition Portal Moderator ExPo Original
    Join Date
    Jun 2005
    Location
    Lander, Wyoming
    Posts
    5,199
    Probably in the "Other Custom Expedition Camper" folder....
    I'll move this thread over shortly.
    - KC
    '97 Toyota T100 - some stuff and some stories....
    '85 Toyota FJ6O - fractal cruising
    currently listening to - Jamey Johnson "The Guitar Song"
    recommended reading - Into the Story by David Maraniss
  3. #3
    Default F 450 flatbed camper build.
    Please bear with me. I work better with saws and a welder then I do with a camera and a computer. I will take pictures as I go but I am not sure how long it will take to get them posted. The base truck for this build is a 2008 Ford F450 4x4 cab and chassis 200 inch WB with a crew cab. 6.4 diesel, 4:88 LS Lariet package. Dual tanks. I will be using the truck to haul a 30 ft gooseneck trailer for work and work out of aluminum tool boxes installed on top and under an aluminum flat bed. For trips I will have a Lance 835 hardside camper taking up 8 ft of the 11 ft flat bed. The extra 3 ft will be for storing a Newholland gas grill and ice chest. During hunting season I can put three dog kennels in the back. The flat bed is 8 ft wide and 11 ft long. I have three sheets of 3/16 bright plate aluminum coming Tues. I have 4 x 4 14ga squ tubing to raise the bed high enough for the camper to clear the cab. The last three ft of the bed will be 4 inches lower, it will be install straight on the bed rails. This will lower the work platform and entry way for the camper. The bed will have Factory made aluminum boxes install on top and underside. Two 24 inch x 14 inch x 16 inch boxes will be installed behind the rear wheels. ON the driver side One 60 inch x 18 x 18 will be under the bed and one 96 inch will be on top of the bed. On the passenger side I will build a 36 x 36 x18 aluminum box to hold the spare tire and jack. That will leave room for one 24 inch box underside and one 60 inch box on topside.
  4. #4
    Join Date
    Sep 2006
    Location
    Canadian in Colorado
    Posts
    1,063
    Sounds great, post some pictures soon!
    '12 Dodge 5500 6.7 diesel slightly modified. 14' 3" Alaskan camper (Alaskanabego)
    My camper build: http://www.expeditionportal.com/foru...ead.php?t=9502
    KD0ERY
  5. #5
    Join Date
    Jul 2007
    Location
    North Carolina
    Posts
    442
    Quote Originally Posted by Capt Eddie
    Good build threads are like a field of dreams - build it and we will come.
    The two closest threads Carlyle (F350 w/ flatbed Alaskan) and jayshapiro (F650 custom camper) are both located in the Domestic full size section. You'll also find useful info in many of the Expedition Camper sections.
    Best of luck with the build.
    Bob
  6. #6
    I picked up the 4 x 4 squ tubing today for the base of the flat bed. At the tune of $100 each for 24 ft. I also looked into a gooseneck setup to go under the bed. I still do not know if I should weld or bolt the hitch to the frame. Any comments would help.I have a spare tire issue to deal with. I have the dual tanks and no where under the frame to hang the spare. It looks like I will have to build a box 36 x 36 x18 to match the rest of the boxes to put the spare in. Tomorrow after work I will start mounting the beams and maybe installing the aluminum plate if it comes as scheduled. I call warn winch about a mount for this truck. They only have the hidden winch mount for now. It puts the bumper out 5 inches,$470 plus $200 for plastic to cover the hole left between the bumper and frame. Any ideas on mounting a M12? I like the idea of a removeable to be able to mount on the rear as needed.
  7. #7
    I was able to get a couple hours of work on the truck in tonight after work. I cut all the 4 x 4 s for the frame and welded tabs on them to attach them to the frame. The big question is if I should weld the tabs to the frame or try to drill and bolt the frame. All the places I went to loking for the gooseneck set up said to weld everything. All the truck dealers sent the truck over and get them welded. If it was going to void the warrenty the dealer would not do it. That was thier reasoning. What does the Expo World think of welding to the frame. The aluminum is going to be here tomorrow.
  8. #8
    It rained most of the morning. This gave me time to go to a fabricator and have a bolt on gooseneck set up made for the F450. This set up has 1 inch x 16 inch flat as the base and 1/2 arms to bolt to the frame. Cost $150. I will do the priming , painting and install. The same design ot of 3/16 installed was $680. I was able to prime and paint all the 4 x 4s tonight in the shop. I will install everything tomorrow night after work. The aluminum plate never showed up. They said it should be here tomorrow. They only come to this side of the state on fridays. I called the Lance dealer this morning to get another female adapter to install in the bed of the new truck so I could keep the one in the Dodge so I can use the Dodge next week to go to Denver for my Grandfather funeral. I know I will not have the Ford ready by then. The dealer said that adapter is only availible thru Lance for $45. I think I will change all plugs to 7 way rv so I will only have one female for the camper and the gooseneck. Alot cheaper and easier to replace.
  9. #9
    Join Date
    Mar 2007
    Location
    The Nanny State
    Posts
    5,726
    Sounds like maybe you've already solved it, but most frames these days are heat treated. Welding on them destroys the heat treat in the weld zone. Can't recall ever seeing a welded-on manufactured gooseneck hitch.
    I would bolt it in the web only (fewer holes in the flanges the better) and use lots of bolt spread out over a large area. It can sit on the flanges, just don't bolt through them.
    I used to swerve around my hallucinations, now I drive right through them.
  10. #10
    All the trailer dealers had weld on and bolt on. I did not like the idea of welding,but they say they dod it all the time. Even my friend that fabricated the bolt on said he welds his presonal one in. It is over now. Now if I can get the aluminum in today.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
