Page 2 of 2 FirstFirst 12
Thread: Question for 4Runner owners
  1. #11
    Join Date
    Feb 2008
    Location
    Flagstaff AZ
    Posts
    444
    My 98 limited is e-locker equiped.
    84/85 Toyota Crawler
    98 4Runner Limited
  2. #12
    Join Date
    Sep 2007
    Location
    Neighbor of the Beast
    Posts
    382
    Quote Originally Posted by Cackalak Han
    See if the rear seal is leaking.
    I think you meant the rear axle seals. Those are noted as problematic. Look for wetness at the bottom of the brake backing plate.
    I haven't taken note of any rear (crank,main) seal issues, or at least isn't common.
    The other common issue is front brakes. They tend to warp rotors. This is often due to the aforementioned rear axle seals leaking and soaking the rear brakes making them useless. The warped rotor fix is replacing with quality aftermarket such as Brembo (not OEM), and ensuring the rear brakes are adjusted properly. There are guys that upgrade to Tundra brakes but it isn't really necessary.
    Steering rack bushings will most likely need replaced. Replacement poly kit is $17 from Wheelers offroad.
    Toyota 4x4
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
