Well after last weekend's stuck. I thought it was time to get duall batts. I looked on line at battery trays but 100 bux just dident work for me. So 14 bux later here is what i have.
this is waht i was afte r
what are you installing it in ? and does it fit ?
"Credo Quia Absurdum"
'97 Dodge Ram 1500 4x (Daily Driver)
'93 XJ Sport (Adventure Vehicle)
yep its fits in my 1993 jeep wrangler
Good job. Must be nice to have that type of room. XJ's sure don't.![]()
1997 Ram 2500 Build & 2004 FWC Grandby Build
2000 Cherokee Classic 4x4, Lots of stuff! SOLD
Follow our adventures at:
OverlandAdventures.Org
Same thought here. Only thing I've seen for the XJ is a double stack unit.Originally Posted by xj_mike
thank you and all in all the box is only 3" longer and 1.5" wider than stock but the frameless wonders are packed
Originally Posted by Maximus Ram
'Mean Green' (no idea if they are still around) did a kit that put one where the stock airbox was, and replaced it with a cone filter.
Back when my 89 MJ was mostly stock, I did a homebrew of the same thing. It was tight, but it worked.
ya, on the cherokee's they want you to remove the stock air box and use and after market air cleaner set up. which isn't a bad thing, but for Kali it has to be a 50 state legal air set up.
I'll have to look at some and see what might be done.
Always nice to have a back up battery or one to run the accessories off of.
If you aren't afraid to do some minor cutting and relocating of the computer you can do something like the diesel battery tray mod as shown on madxj.com.
I'll probably do this at some point. Bigger fish to fry currently.
