I believe you on this, but being the engineer it bugs me when I don't understand. Can you explain a little more how pulling someone out in reverse puts all the torque on the fron axle?Originally Posted by Brian894x4
Joel
Joel
Joel Ericson
- 1997 Toyota FZJ80 (Abu Dhabi)
- 2001 Land Rover Discovery (Abu Dhabi)
- 1998 Toyota T100 (underground giant humidor vault somewhere in Kansas)
So keep'em coming these lines on the road
And keep me responsible be it a light or heavy load
And keep me guessing with these blessings in disguise
And I'll walk with grace my feet and faith my eyes
Because of the weight shift. When going in reverse, the front axle sees all the stresses that are normally reserved for the rear (usually larger and beefer) axle. And especially with a pick-up, where a lot of the time, most of the weight is concentrate on the front with the engine, cab and occupants.Originally Posted by HongerVenture
Add to that, the additional weight from the tow rope pulling the front end down as you tug and if you just happen to be pulling backwards up hill, which is common, even more weight is on the front axle. In fact, in that situation, the majority of the torque and traction could be going through the usually weaker front axle. And finally, if you happen to be turning, the U-joints or CV joints are in a weaker position to break.
Of course, this all assumes you're in 4WD.
Brian McCamish
In Search of History Expeditions
Gresham, Oregon
1995 Toyota Land Cruiser FZJ80 (new expedition rig)
1989 Toyota 4x4 truck w/SAS (retired expedition rig)
www.brian894x4.com (Homepage)
Our Land Cruiser FZJ80 Main Page
In Search of History Page
Abandoned & Active Railroads of the NW Page
Try going to welding supply stores. They can give you a full fill.
The PowerTank unit comes with high end regulator, hose, oil filled gauge and quick connect air fitting. Not sure it justifies the price, but it is high quality.
Sent from my Galaxy Nexus using Tapatalk 2
2009 H3T Alpha Luxuary, off-road package, RD Rock Bashers, SnugTop SlantBack, DOI Front Bumper, Warn XD9000 winch, Viking synthetic winch line, Hutchinson WA-0615 beadlock wheels, OMF Performance rock rings, Cooper STT 315/75R16, Thor Parts rear bumper, OEM UCP, Low profile rear shock mounts, Hunner front skids, Slide Masters Cargo Slide, RAD-1, Cobra 75, Midland 75-822, H3x square tube grille guard, hood louver, locking fuel door, mini-grille, 60" Hi-Lift Jack, CO2 PowerTank, T-bars cranked
I was trying to figure out what Power Tanks had to do with winching vs. pulling.![]()
Tom Rowe
Four wheel drive allows you to get stuck
in places even more inaccessible.
62 88 reg
67 NADA x2
74 Air Portable - The Antichrist (tag 6A666)
95 D1 5-speed
95 D90 5-speed
97 D1 Automatic
Just read the entire thread. Good info on the pitfalls of pulling backwards. I'm going to have to stop doing that.
Jason
I disagree with SOME of the pulling backwards problems mentioned.
Don't write giving someone a quick tug while going backwards off. It all depends on the situation. In some situations the stuck vehicle is going to be STUCK and pulling HARD in reverse is going to be a bad idea. If your trying to go uphill while in reverse while pulling, grossly mismatched vehicles, etc. Some times all the stuck person is going to need is a quick tug to get him off a ledge, high centered, or perhaps on the belly in the snow. Your probably going to put yourself in more danger trying to turn around, rig the winch, etc....than if you would have just used a light pull in the 1st place.
Knowing the limitations and 'feel' of your vehicle is going to be key.
I remember one time spending 3+ hours trying to get this F350 diesel HEAVY truck sunk to the frame in a soft sugar snow pit out. I would pull up to his rear bumper with the truck and have to get a running start with 30' of strap to even START to move him. I was on snow, he was in snow, no winch in sight, had been digging for HOURS. His truck probably weighed 7-8000lbs and was on skinny tires that he REFUSED to air down at all. I was in a 70s short box F150 with a big block and 35s. I wonIt took a LOT of pulling to get him back onto firm ground. That is the only real tool we had at the point that worked.
Project: Doitall Dodge
http://www.expeditionportal.com/foru...ad.php?t=24653
My Unimog camper thoughts and ideas....
http://expeditionportal.com/forum/showthread.php?t=4800
