So i was faced with the dilemma that most of us have...how to mount my hi lift onto my tubular arb bumper. After searching around on the net the only thing i found that is somewhat suitable is this thing made by fourtrex, im sure most of you guys are familiar with. To me the thing looks pretty shady...the hi lift weighs like 50lbs for it to come loose would be disasterous and would cause a lot of damage to the vehicle. The fourtrex clamp is all aluminum, with knob type screw i would be very worried about how titght i can get it without stripping out the AL threads.
Anyway...so I confided in my good friend McMaster Carr...and here are the results.
I got two 1/2-20 4" long bolts that fit into the holes on the light tabs that came with the bumper. Again my main concern was strength so i got grade 8 and also fine thread.
Those nut spacers are 1 3/4 long.
The coolest part are those square washers 1 3/8 x 1 3/8 which perfectly fit into the channel of the jack and eliminate any chance of slack, which could cause loosing of the nuts.
You could get wing nuts instead of hex nuts for the top nuts so a wrench would not be necessary for removal but again i dont want that thing coming loose, getting the wrench out is not that much of a hassle to me.
Everything cost me about $30 with tax, a lot better then $105 from fourtrex.
If anyone is interested i can post part numbers of everything.
