Page 2 of 2 FirstFirst 12
Thread: First mod on my new XJ - Sirius/CB mount
  1. #11
    Join Date
    May 2007
    Location
    Kuna Idaho
    Posts
    364
    So here's my 2 cents worth... i think you could make a bracket that comes from behind the center housing off of the dash frame in there somewhere... not 100% sure about that. The CB can be mounted next to the steering wheel. i mounted my Cobra 75 in that spot in a TJ i used to have. You can reach it easier too...
    1998 Jeep Cherokee SE
    - RE 6130 -HD SYE - Terra 2LO - 31" BFG AT - Dana 30/Dana 44 w 4.10s - ARB Front -
    SawTooth XL Off Road Trailer:
    Expo - Tear Forums
  2. #12
    Wow! Thanks for the Photoshop work. Nice. I originally thought of building a mount over the top of the dash. Here's a drawing I did when I had a JK:
    I made a paper model for this box but it ended up being too high, and to industrial-looking for me. It's a folded box design from sheet metal. It was tough to accomodate the slight curve of the upper dash.
    I will probably put the switches up above the rear view mirror a la Fitch VA with the Sirius attached off the side of the upper switch box. That would keep things simpler around the dash.
  3. #13
    Join Date
    Dec 2008
    Location
    Athol, Mass
    Posts
    1,908
    On top is definately safer.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
