Scepter gas can in a Blitz holder?
Schattenjager
I have a little room under my RTT that would let me store two scepter jerry cans on their side. The only solid solution I can find is the BLITZ red holders. They have mounting holes on the side. The Scepter seems to fit in it OK, I can bolt to my roof rack and use hookless tie downs to secure the can into the carrier.
My concern is that the Scepter does not fit perfectly and I fear that it might wiggle enough to wear into the plastic Scepter.
Anyone done this? Comments? Thoughts? Suggestions? etc etc
angusdevil
The scepter cans will store just fine. Try to use carriage bolts when available. If you are still concerned about the cans wearing out, put on a layer of neoprene or rubber as a buffer. Cheap carmats at walmart work great for this :D
CanuckMariner/Nomad
Love having fun 😊 in the 🌞 by the ⛵ and the ⏳
Why bother with the holders at all, why not just use bungy cords to hold them to your roof rack? Then there would no wear and tear other than where they contact the rack and if you put the bungees just right, that would also be eliminated.
FlyNdrive
Scepter cans also fit in the Front Runner gas can carrier. They are $100.00 for the dual at Equipt.
They are also lockable.
-Ben
Layonnn
-Ben
How easily is that bar that holds then down removable for when not in use?? If that bar can't be lowered i coulnd't get in my garage.
Disco0311
jerry can holder
The Front Runner gas can carrier, it looks really good and solid. But they are out of stock until june at Equipt.
Any other alternatives for a dual holder.
thanks
angusdevil
thanks
Just bolt two blitz carriers together and use a strap to go around the bodies of the cans and another strap to go through the handles. A rubber isolator between the cans would also help so that they don't rub. Shock bushings work really well for this :D
Disco0311
Thanks for the idea.
FlyNdrive
The bar comes off in several seconds without tools. They are held up by the gas cans and can't be supported without them.
-Ben
Ranger4x4dr
option
Build a custom swingout bumper and mount 2 gas cans a Hi-Lift and spare tire and free up the bed and you won't have to crawl on the ground to remove your spare either.
You can also incorporate D-ring attach points that go thru the bumper tube and attach to the frame and a 2" receiver while improving ground clearance and departure angles.
Check the post #3 in this section for a picture in "Gerry Can mounts for tire carrier".
Rinzlerz
