I've posted on other forums but haven't posted here yet.
2" OME lift on disco 1. before the lift, truck drove great. now that it's lifted, truck drives "tight". No problems with wandering at all, only a VERY responsive steer..so much that any little touch changes the course of the vehicle. theres absolutely no play. a perfect example of the steering is when at a stop making a right hand turn, the truck will not correct itself back to center. I have to manually steer it back to center.
There is a very, very slight vibration upon acceleration but is not felt at constant speed, whether on streets or highway. (It's not bad at all)
so...what to do first? could it just be toe in/out and need adjusting? do i need to look at castor correct rad. arms, re-drilled swivel balls, DC drive shaft, DDC drive shaft?
thanks!
~Blake
