Page 1 of 2 12 LastLast
Thread: Tread Lightly Updates
  1. #1
    Join Date
    Jun 2005
    Location
    Prescott, AZ
    Posts
    12,898
    Default Tread Lightly Updates
    I wanted a thread for providing Tread Lightly updates to the forum.
    Tread Lightly has just released a new awareness program
    Tread Lightly Awareness Interactive Presentation (sound)
    Scott Brady
    Overland Journal
    D1 | LJ78 | LR4 | MKIII | J8 | G-Wagen |
  2. #2
    Join Date
    Jul 2006
    Location
    Roxborough, Colorado
    Posts
    836
    Thanks for the link. I just took the course.
  3. #3
    goodtimes's Avatar
    goodtimes is offline Expedition Portal Moderator Expedition Poseur
    Join Date
    Jul 2005
    Location
    Tucson
    Posts
    4,922
    Scott, couple things I noticed that can be passed on as you see fit.
    First, page 24 (the scenarios page) does not work. I can get through the description, but when I try to click on the individual scenarios, I get nothing.
    Second, page 27 will not load.
    Finally, when I follow the "resources" link at the bottom....the list of links that opens in the pop up window are screwy. Several of the [text] links are on top of each other.
    All of these are present when running firefox. I cannot view the site in IE for some reason. As soon as I either click the link, or paste the address into address bar (of IE), it closes the window. Not sure what that is all about.......
    Anyway, it is nice to see them continue to reach out to the public....
    "Life is meant to be enjoyed, not endured" ~someone
  4. #4
    Join Date
    Jul 2006
    Location
    Posts
    836
    I went through the whole course without any issues. Everything loaded fine.
  5. #5
    goodtimes's Avatar
    Join Date
    Jul 2005
    Location
    Tucson
    Posts
    4,922
    I tried again with IE, this time with Norton disabled....same problem, it closes the window before anything loads.
  6. #6
    Join Date
    Jul 2006
    Location
    Posts
    836
    That's strange. I'm using IE but have the McAffee sofware. I used to have Norton but ran into problems every once and a while. With the McAffee haven't had any issues.
  7. #7
    Join Date
    Aug 2006
    Location
    Sugarloaf mtn, Boulder, CO
    Posts
    841
    I had the same problem and it is because the window opens as a pop up, if you have any pop up blocking software it will be closed before it has chance to do anything.
    Most pop up blocking software will allow the window to open if you are holding CTRL when you click on the link.
    Rob
    You don't inherit the world from your parents, you borrow it from your children.
    1979 Unimog 416 Expedition Camper
    1974 Unimog 421
    2004 Dodge Ram 2500, 4x4, Double Cab, Cummins Turbo Diesel
    2006 25' Airstream International CCD
    2009 Harley Davidson
    Sugarloaf, Boulder, CO
  8. #8
    Join Date
    Apr 2006
    Location
    Lyon County, Nevada
    Posts
    224
    Thanks for the "ctrl" button info. It works.
    Rocky - Trans-Nevada-Trek Trail Boss - '04 Land Rover Discovery S
  9. #9
    goodtimes's Avatar
    Join Date
    Jul 2005
    Location
    Tucson
    Posts
    4,922
    OK, there must be some old popup blocking software running on my computer. With Norton enabled....it isn't going to load. With Norton disabled, the <<ctrl>> + clicking on the link works.
    It appears that 2 of the 3 problems I had were associated with Firefox. But when I click on the "resources" link, the "text on top of text" problem is still there....but the problem is in a different area of the screen.....
  10. #10
    Join Date
    Aug 2006
    Location
    Posts
    841
    I am seeing the text on text problem in the resource window in IE too. I use a larger than normal font and it has caused problems like this in the past.
    Rob
    1974 Unimog 421
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
