I Know I Know search search search, but who makes a reasonable propane (preferred) hot water shower unit? I found a cheepy privy from sportsmans guide for $39.
Aaron
Aaron
Go for the Zodi, I like mine.
Both my vids below.
http://www.youtube.com/watch?v=C9hrjcbRsYM
http://www.youtube.com/watch?v=XzI-sXNrIFA
I second that. We really like our Zodi. We use the shelter from P.E.T.T. (multi-tasker). Spend the money, cry once....
2008 T4R SR5 V8 w/2-1 Revtek lift & 265/70-17
AT Chaser
Single burner or dual burner? Figure this time around 3 people using it (not at the same time). I will need some water tanks (will work on that tomorrow).
Aaron
Check out the Coleman Hot Water Shower.
It its kind of heavy and bulky but it works great.
Desert Dan
2006 Toyota 4-Runner SR 5/OME Suspension GY MTR's
Jeep TJ Rubicon 2003/3.5" RE SF/Warn Winch 9500TI / BFG KM2's
Gone - But- Not Forgotten 4x4's
2006 Hummer H3
1994 Jeep YJ
Dodge Ramcharger 4x4 (ACSC-Company Truck)
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Showers use up water at an alarming rate.
I'd suggest if you want a propane shower you go with the Zodi Hot Tap. It limits the shower to 4 gallons of water. The single burner works fine. 3 people can take showers one after the other, no problem.
Learning to take "sailors showers" is the key here. Turn on the water to wet your hair, turn the water off and wash your hair, use this wet soap to wash your body, use a minimum amount of water to rinse. A full shower with under 20 seconds of water use.
I agree with Martyn here and the Hot Tap is the shower I've been thinking about picking up for my trip. All contained in a nice small box, I think 4 gallons should be more than enough for one person. Besides, I'm not expecting some fantastic shower while I'm in a pop-up tent in the middle of nowhere...if I was I'd just stay in a hotel!Having hot water is the most important thing on my list!
It really makes you think about how much water you waste at home everyday in the shower.
Heidi - KF7CKI
Sierra Expeditions
1-866-507-4254
1998 4Runner SR5*~*2009 Kawasaki Super Sherpa*~*2009 Voo Doo Dambala
Two Libras
Aaron, two different type of Zodi's were mentioned here too.
The Hotman Extreme like mine is four gallons:
http://www.zodi.com/web-content/Cons...emeshower.html
You have to heat the water first with the included burner which can also double as a stove for big pots.
I modified mine with a kitchen faucet sprayer which gives me more control.
Then there are the other two ones that have the single/double burners.
Hot Tap On-Demand Hot Shower
single
http://www.zodi.com/web-content/Cons...velshower.html
double
http://www.zodi.com/web-content/Cons...phpshower.html
I went for the bug type sprayer for ease since it is all self contained pretty much, saves me some space which is not a lot in the FJ Cruiser.
In my experience you wont need a dual burner Zodi.
We shower as Martyn described when we need to conserve water, but it's nice to not have to. Last camp 3 of us showered with under 5 gallon.
You MUST have the pump running whenever you have the burner lit, otherwise you risk a meltdown of the heating element. But thats easy to avoid. I preheat the water before showering. The Zodi pump drops into the Scepter/LCI MWC spout nicely, i keep one can for shower supply.
Another tip for decent pressure is to raise the source to waist level or close and the exchanger to shoulder height. I stole one of the wife's iron flower pot hanger for this purpose. Works fantastic.
Got one on hold at Bass Pro. Zodi single burner.
Aaron
