Thread: exhaust clearance?
  1. #1
    Join Date
    Jun 2007
    Location
    Marquette, MI
    Posts
    85
    Default exhaust clearance?
    Need some help. My exhaust on my 1996 tacoma hangs down too low. Where is a good place to route it higher. Any reason I can't have it terminate under the bed? Thanks, Ian
  2. #2
    your state may have laws on where it can terminate in relation to the rear axle or cab etc
    if you plan on dumping it under the bed it will definately be louder in the cab
    you might want to consider heat sheilding anything near it as well if you move it. It's really easy to think "there's enough room/air" and burn up something important, like brake lines etc
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
