Page 1 of 2 12 LastLast
Thread: Proper intro and my '04 Tacoma
  1. #1
    Default Proper intro and my '04 Tacoma
    Hi everyone,
    Just wanted to introduce myself properly. I'm Ed, from the San Francisco Bay Area. Been lurking here and posting for the last several months, so out I come officially.
    My rig is a 2004 Tacoma Extended Cab 4x4. The mechanicals are more or less bone stock and the mods sort of come and go as I find what works and what doesn't.
    Present form:
    -SAW 2.0's up front, Fabtech AAL on the rear for about 2" of moderate lift
    -Hayden 678 Transmission cooler; had the TRD until a rock rendered it
    beyond salvage.
    -ARB front bumper w/ WARN M8000 winch (no, I didn't do the endcap mod
    yet, and so far, no problems) and a pair of KC Daylighters
    (Formerly mounted with a WARN Trans4Mer mount - worked well, had
    zero problems with it, but I gained clearance by going to the ARB)
    -Front Range Offroad Rear Bumper (modding it this weekend to better
    accomodate my receiver)
    -Bluesea fuse block on the passenger side interior kick panel that handles
    lower-draw lighting, CB and HAM radios and will handle a planned rear
    12V powerpoint once I find a good way to set something up.
    -Class III receiver for recovery (also used to tow my teardrop when I still
    had it [kicking myself for selling] with a WARN receiver shackle
    -Uniden CB with a custom 2 piece antenna mount (rear of truck, handmade
    of aluminum bar stock - works really nice, 1.8:1 SWR w/ Firestick)
    -Kenwood TM-D707 with a Radial-Larsen glass mount (also works
    amazingly well for a through-glass antenna)
    -ARE topper
    -Custom rear cargo light (switchable from the cab and the bed)
    -Custom HiLift mounts in the bed (just 2 pieces of hand-bent steel bar
    stock and some big bolts to hold the HiLift and my shovel.
    What's coming:
    -Set of BFG MT T/A KM2's being installed on stock 16x7's tomorrow morning
    -Couple sets of 5" Core-Trax tiedown points I have to install on the inside of
    the tailgate to act as anchor points for my NATO cans.
    -Going to turn half the bed area into a sleeping platform and storage and
    leave the other half open for additional, non-integrated camping gear
    (EZups, kitchen box, etc.) To date I've not seen a "half-and-half" setup
    like that, so I'm going to get busy with my tape measure and figure
    something out.
    What I'd like to add:
    Dual battery setup, preferably using a manual marine-type switch. Problem is, I'm not keen on putting the 2nd battery in the bed, enclosed by the shell and then also sleeping back there. Thoughts on this?
    Aux. fuel tank, similar to the Expeditions West setup. Living in California makes that dubious, however.
    Rear utility lights - this is just a matter of time and materials.
    Roof rack + cargo basket - just a matter of time and money.
    What I do - I'm a Unix sysadmin for a tech company in Silicon Valley. I'm also a licensed California attorney with a small side practice (how's that for oddball?) The truck is used for fishing (flyfishing, usually) and camping mostly in the Sierras. I used to make frequent treks into NW Nevada (many of you know what I'm talking about - basically anywhere from Cedarville/Lake City -> Vya -> Nixon -> Lovelock ->Blackrock Desert -> High Rock Canyon -> Kumiva Valley and so on), but they're less frequent since buying a home and having a kid.
    Better and more pics (with detail) to come. This is all I have handy at my desk.
    Thanks!
    -Ed
    Attached Images Attached Images
  2. #2
    Join Date
    Nov 2005
    Location
    The country of TEXAS!
    Posts
    354
    Hi Ed!
    Nice Taco there!
    Ciao! - - Nathan
    '01 Tacoma DCab (some mods - click here)
    + '00 BMW Z3 (more mods) + '12 MINI Countryman ALL4
    EX-PO Member since Nov 18, 2005 - - TTORA Member since Nov 18, 2005 - - TLCA Member since June 4, 2008
  3. #3
    Thanks! It is a work in progress.
    Years ago when I built my teardrop, I really figured that would be my solution, instead of outfitting the truck proper. And for a while it did just fine. But with the addition to the family (and maybe more in another year or two), I could see that plan wouldn't work out too well.
    I'll get more pictures and some build threads going as I move ahead with my plans. Eager for feedback, too. There are some hardcore explorers here that know worlds more about this stuff than I do!
    For example, the truck (up until a month ago) had a BudBuilt skid on it. It's a quality unit and I was happy with it, save one thing - the weight. Between that, the ARB and the winch, my tires would groan like a mofo (even at 34PSI) when turning the wheel at a dead stop. And upon reflection, I don't crawl rocks or go places likely to *require* a Budbuilt. Of course the problem could also be the cruddy stock tires. So once the BFG's are installed, I'll probably re-add the BudBuilt and see if that changes anything. Always "in progress" it seems.
    Quote Originally Posted by TEJASYOTA View Post
    Hi Ed!
    Nice Taco there!
  4. #4
    Join Date
    Dec 2006
    Location
    Nor Bay Nor Cal
    Posts
    327
    I am in the East Bay- maybe we can hit some trials.
    85 Hilux ExpoCrawler
  5. #5
    Join Date
    Jun 2007
    Location
    Phoenix, AZ
    Posts
    348
    Hi Ed,
    I think I saw your truck on the 101 north of the Gate a few months back. The two lights with the smiley faces on top of the bumper is what I recognize. What part of the Bay Area are you in? I am up north in Rohnert Park.
    I got away without an endcap mod till about 75,000 miles, but the truck had seen a lot of washboard two-tracks at speed. Just keep checking your bumper by seeing if you can wiggle it fore and aft from the top bar.
    2004 4dr V6, Donahoe coil overs, Camburg arms, manual hubs, Deaver springs and Bilsteins in the rear. Light Racing Jounce Shock System (Front & Rear) Demello rock sliders and rear bumper. Bud Built IFS Skidplate and Belly Skidplate. BFG 33X10.5 tires. ARB bumper and Warn XD 9000 On board air. CB, in dash moving map, ScanGauge II gauge. IPT Valve Body Upgrade Truck Page
  6. #6
    Join Date
    Dec 2005
    Location
    Temecula Valley
    Posts
    9,768
    Nice truck. Welcome to ExPo Ed!!!
    Dave Bennett, Member #203
    Travel, Explore, Live: AMERICAN ADVENTURIST
  7. #7
    Join Date
    Sep 2007
    Location
    Central Nowhere, NA
    Posts
    4,452
    Welcome aboard!
    Tacoma - For Extended Overland Travels
    2012 FWC - The TARDIS
    Trip Reports - Travels with Hadley
    -Nathanael
    Large Format Photography
    www.KuenzliPhotography.com
  8. #8
    Join Date
    Jul 2007
    Location
    Long Beach, CA
    Posts
    1,032
    Quote Originally Posted by obscurotron View Post
    Budbuilt offers aluminum versions of his skids as well (they're not advertised, but can be requested if people are interested.) Perhaps selling your steels and picking up some of the lightweight version would meet your needs.
    KJ6FWX '99 4Runner Limited 4WD E-Locked
  9. #9
    Last time I was on 101 north of SF was about a year ago, so it may not have been me. I'm on the Peninsula, in San Mateo.
    I will keep checking the bumper. The way the ARBs mount (at least now), I can see the endcap a bit, so I'll have a good visual if it starts to let go. Thanks for the heads up!
    Quote Originally Posted by PHXtaco View Post
    Hi Ed,
  10. #10
    I considered that, but at the time Bud didn't have enough demand to do another run of them. He was also out of the 1/8" steel version. I'll bide my time for now, but yeah, the steel 3/16" BB skid may be up for sale soon.
    Quote Originally Posted by CYi5 View Post
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
