Thread: Let's see your Series Land Rover
  1. #91
    Join Date
    Apr 2009
    Location
    Bedford, UK
    Posts
    566
    That sounds like an engine mounting has worked loose or failed - the rubber sometimes perishes ot goes hard, or it can come away from the steel end plates. Shouldn't be hard to find...
    It's not broken, it's British!
    www.nickslandrover.co.uk
  2. #92
    Join Date
    Apr 2009
    Location
    The Netherlands
    Posts
    168
    Nope. They're still good.. This is also on the side where the motor rubber gets pulled on. They're still ok. This vibration wasn't there yesterday. So today I must have done something (I've played around near the tranny tunnel) that must be the cause of this. There's very little clearance between bellhousing and tranny tunnel. I have to redo the tunnel sometime soon, make it bigger.
    It gets annoying, there's always something needing attention. Sometimes (at the moment a bit more than I used to) I just wished I could drive a completely bog standard factory vehicle (not a LR to be honest) just so it would be a quiet comfortable ride... a vehicle that just needs routine maintenance instead of this constant neverending attention to all these little things.. sigh... oh well..
    - '65 112" Series IIa
    3B diesel,TD04 turbo, Saab intercooler, H41 4speed, 4:1 Orion, SOA HDJ80 axles, HellFire Fabworks high-steer, PAS, dual E-locked, rear springs up front, 63" chevy rear springs, 5125 14"Bilsteins, 4door no-top/softtop, OBA, custom dash, custom 120ltr alloy fueltank and a few more things...
  3. #93
    Join Date
    Apr 2009
    Location
    Bedford, UK
    Posts
    566
    Ha - I have to keep on top of a Lighweight and RRC too! I might as well move my bed to the garage!
  4. #94
    Join Date
    Sep 2007
    Location
    Conifer, CO
    Posts
    1,959
    Man this thread just feeds my addiction... I so badly want a Series.
    '92 Range Rover
    '93 Range Rover LWB
    '71 Mercedes 220 Diesel - The daily Beast
  5. #95
    Join Date
    May 2010
    Location
    Hampshire, UK
    Posts
    58
    This is my '76 SIII. Approved by my youngest daughter Bought it a few years ago, in running condition, for £400 (circa $595)
  6. #96
    Join Date
    Oct 2009
    Location
    CA
    Posts
    258
    Quote Originally Posted by Toy-Roverlander View Post
    I can't use standard insulation sets made for Series vehicles as I got a totally different trans tunnel and lever layout. The rear passenger and cargo floor are totally different too. I know what stuff I want to use. I just want to get rid of most of the rattles and such first. I got rid of the most annoying one (startermotor hitting 2 of the 3bolts that hold the bulkhead support plate to the chassis on the left hand side on acceleration). But now it developed a new one, it now all of a sudden vibrates more at idle and it resonates through into the rollbar and rear floor area.. bloody annoying!
    Four cylinder diesels are annoying no matter what. When I use to maintain a fleet of 4bt cummins powered delivery vans. I was constantly tightening various, miscellaneous stuff. One time I had to re-rivit the body panel sides. They vibrated lose!! Hydraulic engine mounts(gel type) seamed to help a bit, but still a pain. I used dynamat to insulate my firewall and trans tunnel cover works good. BTW,your truck is very cool!!ImageUploadedByTapatalk1363135849.689804.jpg
  7. #97
    Join Date
    Mar 2010
    Location
    People's Republik of Cambridge & Malpais
    Posts
    302
    Default A new friend of the family...
    1958 Series I 88" frame off full restoration
    Not original engine, but the 2.5 petrol is fresh and runs fantastic
    No name yet....
    Toltec Rally Team
    www.toltecrally.com: What would Steve Zissou do?
    '02 WRX Super Production Class Rally Car: now wikked fastah
    '99 UZJ100: Our well armored grocery getter
    '76 Diesel Series III 88: trying to become a US citizen
    '94 FZJ80: Betty is now officially Tica
    '95 RRC LWB: our new project/problem child
  8. #98
    Join Date
    Sep 2012
    Location
    United States
    Posts
    464
    Wow, that is beautiful Redrum!
    Zack
    Rovers North Photographer
    2002 Land Rover Discovery II Outfitted Photo
    2004 Volvo S60R Track suited http://www.flickr.com/photos/zgriswo...0736/lightbox/
    2005 Suzuki SV650S http://s18.postimage.org/xwjb3owix/bie.jpg
    2008 Honda CBR600RR Graffiti
  9. #99
    Join Date
    Apr 2013
    Location
    Netherlands
    Posts
    2
    I've been frequenting this forum as a guest for a while but when I stumbled upon this thread I didn't want to withold you guys some pictures of my 1977 Series III carawagon. After I bought it in mid 2012 I have done some conversions to make the car more suitable for camping and extended travel. Nothing major, just small things here and there to make using the car more enjoyable. She is still a work in progress and as usuall, plenty of idea's but a bit short on fundings
    The car pretty much in it's current state
    Put on a roofrack and tent I found on a swapmeet
    Lockable tube for tent poles and fishin rods
    Put on a simple awning
    Made a small cabinet for the corner in the roof. (still a work in progress) which actually holds quite a lot of stuff
    And to end just a nice picture driving my series through the fog at night!
    Cheers!
    Wouter
  10. #100
    Join Date
    Apr 2009
    Location
    The Netherlands
    Posts
    168
    Quote Originally Posted by blue bomber View Post
    These big 4 cylinders sure vibrate heaps. Not long after I found the cause of the viration on mine. A bolt that fixes the exhaust to the rollcage had lost its nut. The bolt was vibrating against the tab on the rollcage, hence the noise and vibration went through the cage. And due to the bolt not being tight the exhaust moved a bit an was touching the body. All fixed now.
    That rattly old diesel even ripped of the front fixing tab of the exhaust, even though it has a flex joint in it right after the turbo.
    Hydraulic engine mounts sound interesting!
Page 10 of 12 FirstFirst ... 89101112 LastLast
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
